Home > Help Needed / General Tech Chat > Clutch problems?
The problem is, when you press on the clutch pedal there seems to be no resistnace until you get to the last 1 inch of travel at which point feels normal.
Its on my brothers mini, and all I know is he changed down a gear after that he heard a knock and the pedal is as above.
I had a look to find the return spring missing, fitted that but now he can't engage any gears? Took it back off and now he can?
Im thinking that the problem is the master cylinder leaking as it is 30 years, old and the slave cylinder is a year old?
Anyone recognise these symptoms at all.
Sorry about the ramblings, hope it all makes sense!
Matt
Try rebleeding the system then adjust the the adjustment bolt (the little bolt that sets how far back the arm comes) in accordance with the Haynes manual.
wil
Yea that could be worth a go actually, not sure how common air lock are in the clutch system?
The master cylinder was only topped up to half way when i looked!
i had this happen when i had fitted an R clip to the master cylinder pin, the clip came off and the pin poped out, the pedal still pushed the master slightly even without the pin.
worth a look.
is the clevis pin in? i lost mine and it gave the same sympoms
yeah, clevis pin, that what i meant, couldn't bloody remember the name of it...
Yea I used an R clip aswell, as there a pain in the arse trying to get a split pin/out. Could well be that by the sound of things. :(
i get my neighbours kid to do it, 8 year old have perfect sized hands lol
sigged
Ric
Member #: 36
Basingstoke
hahahahahaha! dirty bastard! *wink*
Thats wrong, I guess there the perfect size because there smaller? Lol *laughing*
Haha problem solved and didn't even break a nail :)
Mini13 and Wolfie were spot on.......Clevis pin.
Cheers lads now I can get on with mine. :)
Ahh good, glad it was an easy fix,
do you have an R clip in the prake clevis?
Not sure..im guessing if it were to have one, then it wouldn't be too safe!*blush*
I"ll have to check!
Edited by matty on 20th Nov, 2006.
