Home > Wanted > Shocks! - cheap as pos and quick as pos
Yo
Got my new shell, but it needs shocks before I can put it on wheels to roll it into my garage - so it'll be getting all wet until then.
so, do any of you lot have an old set of shocks I can have/buy cheap as a temp measure until I can buy some decent ones?
al.
you dont need shocks to roll it round mate
do i not?
what do i need then :)
nutter driver
Member #: 47
Not very sunny swanage
suspension cones and trupets, or failing that, a peice of something wedged in the gap where the suspension should sit will allow you to roll it around.
Ah right, cheers.
thats what I need then.. *wink*
At the rear end - you need to get a piece of steel tube that slides nicely over the 3/8" stud where the shock-pin is and hangs out around 1-2", this will rest on the underside of the subframe and prevent the wheel going into the arch without any springs or trumpets in there aswell....
right
just found some as new hi-lo for the rear
ill bring them with me sat
now you need complete radious arms inc hubs bearings and drums and cones to get the rear rolling
front you need top and bottom arms hubs cv joints ect and cones and knuckles .... i may be able to source these in the morning
Dont worry about it Neil - I'm nicking all the stuff off the frog anyway, so i just wanted to bodge it to move it into the garage. Perhaps one of those rigs with wheels that you put unpainted bodys on would be better?
I've got a set of hi-los in the garage ready for the new shell.
I'll speak to my mate with a VW garage tomorrow, see if he has anything I could use.
Go round the back of kwik-save and see if there are any bread-trolley bases lying around.
I understand they work REALLY well *wink*
ha ha, thats a great idea, but we onyl have a saino's and its guarded 24/7 :(
i have a couple of the trollys the move the tote boxes round on if there any good?
I have got a pair of complete radius arms, and a pair of standard rear trumpets. Also a set of standard bottom arms/tie bars.
Let me know if you want to borrow any of it?
