Home > Help Needed / General Tech Chat > Crank endfloat
Done a search but cant find the answer.
I measured the crank endfloat on strip down of my A+ 998 at 0.004"
My latest Haynes say that it should be 0.002 to 0.003.
An old Haynes, pre A+, says 0.001 to 0.005.
I'm sure I read somewhere in one of the Vizard books that you should increase the clearance over standard for high performance use.
The problem is that, even if I could get hold of some +0.003 thrust washers, I would then have only 0.001.
Shall I leave it as it is?
1 thou in my opinion is too tight.
I have heard of engine builders that recomend about 7 thou (although thats for higher reving stuff) as long as it's all in good condition i'd leave as is.
nogin
Member #: 487
westbury, wiltshire
i got mine at 2 thou, you kind of need this for the heavy clutches, you can always use a bit of wet and dry on one side to make the gap bigger
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Scruffy
Member #: 328
Seaford Rise, South Australia
What do the old thrusts actually measure? Are they worn by a thou or two? Can you mike them up and compare what a new one is?
On 5th Sep, 2011 Vegard said:
id leave as is tbh
infact, the 1380 na engine im putting in my rally car has 4 thou endfloat..
Which clutch spring are you using?
I would never use 0.004 better get it down towards 0.002-0.003. It's easy to get osm 0.003 thrusts and sand them down or having them milled down. If you aren't prepared to do such stuff, you shouldn't be building engines.
orange, i know its nearing the "outer" tolerence, but the way i see it is the oil will take up a thou or so too..
anyway, im happy to give it try, even if some people would consider it a bit of a loose build.
If its a disaster, ill put o/s thrusts in when i put a new box on in the new year.
