| Home > Technical Chat > CR / bore / PSI ? | |||||||
18th Nov, 2006 at 05:57:10pm
Hi all, im sorry if this has been asked before or sounds like a dumb question but i have attempted to do some reading on CR's and use Alex's compression ratio calc on the AF racing site.. but i still dont really understand it or what i need to achieve.
Edited by MarkGTT on 18th Nov, 2006. |
19th Nov, 2006 at 02:10:08pm
what pistons? std metro turbo?
19th Nov, 2006 at 02:24:22pm
Hi, thanks for the reply.
Edited by MarkGTT on 19th Nov, 2006. |
19th Nov, 2006 at 02:31:14pm
in that case you should be able to run more assuming the 8:1 is correct, do you have any idea of the piston dish size?
19th Nov, 2006 at 03:14:11pm
No idea on the dish size.. sorry. and as far as i know the box is standard. If i can afford it in the future this will be uprated.
19th Nov, 2006 at 04:04:34pm
yeah, i'd advise doing something with the diff as this is the weakest point,
19th Nov, 2006 at 05:56:17pm
Cheers for the sound advice, im past the wheel spins etc now, but want to give it some stick on the track at some point. So i will take your advice, 120bhp and sensible driving :) until funds permit for me to push it harder.
19th Nov, 2006 at 07:03:53pm
enjoy!!
19th Nov, 2006 at 07:18:37pm
funny you should say that i have been reading up on megajolt over the past few weeks, looks like a great option. How difficult is it to get the timing right with the megajolt system? because its currently a pain with the dizzy. |
19th Nov, 2006 at 07:34:12pm
The main advantage to the megajolt is that you can retard the timing as bost pressure increases. It is difficult to achieve this with a dizzy.
19th Nov, 2006 at 07:59:55pm
yes, what Tom says, also being 3d (jolt is 3d right? I've only used megasquirt) part throttle can be advanced up making cruising much more efficient. On 28th Aug, 2011 Kean said:
