Home > Help Needed / General Tech Chat > will only run on low fuel pressure??
sauber 200
Member #: 245
hi guys.with fuel pressure set at 4.5psicar will only tickover for a
short time,to get the car to tickover correctly i have to reduce
fuel pressure to 3 psi ,but with lower pressure turbo doesnt seem to respond as well as on higher pressure,
thanks paul...
Check the float bowl needle valve, it might need adjusting or renewing
Wil
