| Home > Help Needed / General Tech Chat > Trigger disc setting up the timing? | |||||||
138 Posts Member #: 138 Advanced Member |
20th Nov, 2006 at 09:08:06am
I am going to mount trigger wheel from mini-pulleys.com, So do I need to set up engine timing, As i cannot see it being adjustable on crank. or is there more to it?
20th Nov, 2006 at 09:31:51am
no, its ready machined so that the missing tooth is at tdc
567 Posts Member #: 102 Post Whore Pennsylvania USA |
20th Nov, 2006 at 10:09:48am
I also got the bracket from Tom. It makes it much easier. |
20th Nov, 2006 at 01:55:29pm
just a quick question on this topic,
20th Nov, 2006 at 02:00:50pm
Yes but check as there may be a few degrees difference which will need to be accounted for either in the map or if the ECU has compensation a la emerald.
20th Nov, 2006 at 02:13:50pm
Bolt both the pulley and bracket on and off you go!
20th Nov, 2006 at 02:18:51pm
i've got one of toms sensor brackets and it was spot on, even with my timing wheel that was courtesy of doodmeister. On 20th Oct, 2015 Tom Fenton said:
20th Nov, 2006 at 07:05:06pm
Looks like i should drop Tom a mail then :) Where is the best place to get the megajolt kit? Alex? |
20th Nov, 2006 at 07:28:43pm
20th Nov, 2006 at 07:52:17pm
Cheers guys. Vrooom, sorry for hijacking the post.
just silly not to check.
