Home > General Chat > engine or bodywork??
clubman_dan
Member #: 142
Winchester
now that i have a cheap way of getting discs on my car and when i sell my moped i should have some extra cash do i turbo the car now or do the bodywork ( starting to get rusty)
turbo now bodywork now buy a mig welder and learn how to use it, then do both1 Votes 1 Votes - 10%
evolotion
Member #: 83
Glasgow, Scotland
voted 3 because thats what i did :) the mig is a totally invaluable tool as a mini owner, besides when u come to turbo ur guna need a bulkhead box welded in anyway.
Denis O'Brien.
nutter driver
Member #: 47
Not very sunny swanage
definately get a mig......
clubman_dan
Member #: 142
Winchester
how didi you learn how to use the mig evolution?
did you just practice on scraps of metal??
evolotion
Member #: 83
Glasgow, Scotland
basically i front ended my little brothers mini, couldnt afford to buy him a new one and couldnt afford to ge tit fixed, so bought a mig.. Just read a few tutorials on teh net and practiced :)
Good bit of advice tho, practice on good rust free un-painted sheet steel as its easy as fook to weld. then move onto rusty stuff. .. wel by rusty i meen old (cleaned up) car bodywork.
Edited by evolotion on 2nd May, 2004.
Denis O'Brien.
clubman_dan
Member #: 142
Winchester
o.k i'll give it a try, i have a book about bodywork repair with a section on mig welding so i'll buy some sheet metal and start doing it
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Also, can i just ask, if you find any tutorials will you post htem? Ive only found some rubbish from school collage projects on google, no valuble tips etc.
b12
Member #: 247
Kent/Surrey Borders
MIG MIG
Cleanleness is the key
make sure there is absolutley nothing on the the work Paint, Grease , OIL are your worst enemy
Use a angle grinder with a wire brush and make that metal shine !!!!!!
Use CO2 and Argon mix .... I find this works vWell as there are less impurities in the gas
Then its all down to output power and wire speed
Now that come with practise !!! Right guys !!!
Steve
Edited by b12 on 3rd May, 2004.
TurboLessTosser
Im just doing the same thing, going to tidy up the patchwork quilt thats called my mini's floors! lol!
Just need to order the panels now, im going to be sandblasting locally to get everything very clean.
clubman_dan
Member #: 142
Winchester
i think i will go the diy route with the welding,
for sure, i just can't afford to have it done at a garage on my tax evading stundent wages
Arno
Member #: 233
Beugen, Netherlands
b12 is right, cleanleness is most important, you cannot weld rust or oil, you can only weld metal.
Good luck
