| Home > Help Needed / General Tech Chat > limping car! | |||||||
255 Posts Member #: 520 Senior Member nr hull |
22nd Nov, 2006 at 09:35:15pm
hey up all,
doh! why did i start messing with it!
23rd Nov, 2006 at 05:34:07am
Have you checked the shafts are still intact?
23rd Nov, 2006 at 04:50:13pm
yeah driveshafts are still in one piece, output shafts might be a different story doh! why did i start messing with it!
23rd Nov, 2006 at 04:51:39pm
Sometimes you can bust a cv joint and the shaft will still stay in one piece. Remember that with a plate diff if you bust one shaft you will still have 1-wheel drive which might explain the odd feeling when driving it.
23rd Nov, 2006 at 04:58:00pm
will have a look tonight mate, i never thought about looking in that end of the shaft tbh! oh i have to admit i was being a bit naughty and trying the slicks i got off iain out at the time which explains why it snached so badly. i just couldnt resist it and hell they get sticky quick lol :$ wont be doing that again in a hurry
23rd Nov, 2006 at 05:00:06pm
Well from that further info almost without a doubt a bust CV, slicks as you have found out have a LOT of grip, one side with loads of grip and the other on a cow pat and then the sudden shock load as you find some grip has finished something off.
23rd Nov, 2006 at 05:07:09pm
lol planning on taking the engine out tonight anyway so will have the whole lot off and will find out for sure. im sure there will be some nice parts to go on the shelf of doom in the shed, theres a nice steel flywheel with half a crank nose friction welded in it, numerous bent tie bars, a chocolate layshaft, and 1/2 a grey diaphram which just exploded for no apparent reason!
23rd Nov, 2006 at 05:43:44pm
did it pull one way on throttle and dive the other when you lift off? On 28th Aug, 2011 Kean said:
23rd Nov, 2006 at 05:55:39pm
no it was more pull one way and then as normal when throttle was off. it was pulling hard enough so that i was having trouble keeping the steering wheel central. doh! why did i start messing with it!
23rd Nov, 2006 at 06:00:17pm
it does sound like you have 1wd
24th Nov, 2006 at 04:47:10pm
hey up didnt have enough time to check everything last night, but i noticed the oil level was very low. i only topped it up a few weeks back but obviously it was using/loosing a tad more than i thought!
24th Nov, 2006 at 07:50:50pm
update... cv's all present and acounted for Edited by hippyinamini on 24th Nov, 2006. doh! why did i start messing with it!
24th Nov, 2006 at 07:56:14pm
might be worth a close look round the suspension arms, maybe a sudden "tug" one side has moved/bent something/ killed a bush ect. On 28th Aug, 2011 Kean said:
30th Nov, 2006 at 09:43:23pm
well update!
will have to get it taken to bits i suppose. hopefully its something glaringly obvious.
