| Home > Technical Chat > waste spark thought | |||||||
24th Nov, 2006 at 12:37:15pm
i was just making some new leads for the spud ,
24th Nov, 2006 at 01:00:01pm
Intersting point,
Edited by Joe C on 24th Nov, 2006. On 28th Aug, 2011 Kean said:
24th Nov, 2006 at 01:11:10pm
These kind of ideas are interesting to think about and mull over, but surely an extra pound of boost would have a far greater effect on power output?!
24th Nov, 2006 at 01:19:07pm
True, only so much boost you can run though On 28th Aug, 2011 Kean said:
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
24th Nov, 2006 at 01:54:34pm
also this could potentially have a positive effect on the effiency of the engine. Although, i'm the first to admit that most of that post went way over my head! |
24th Nov, 2006 at 02:36:15pm
Has anyone got a circuit of how the coils are wired (HT side).
24th Nov, 2006 at 02:38:57pm
I personally thought that the coil packs (as per Fiesta type) are two individual coils, that fire both cylinders at once, in the "normal" positive way.
24th Nov, 2006 at 03:16:04pm
yes EDIS coils are really two coilpack, like Tom wrote above. |
24th Nov, 2006 at 04:05:25pm
Ive worked on a lot of Subarus which have coil packs.
Edited by stevieturbo on 24th Nov, 2006. 9.85 @ 145mph
24th Nov, 2006 at 05:07:01pm
Basically in the coil pack there are 2 coils, I think everbody knows that. Each coil is charged and discharged in the normal way, i.e remove voltage from the coil and the magnatic field brakes down and a high voltage is produced. The difference in the wasted spark coil is that the coil is centre tapped, so that when you get the HT pulse you get one +ve pulse and one -ve pulse simultaneously.
http://www.twin-turbo.co.uk
24th Nov, 2006 at 06:05:33pm
I blew up a coil pack a while ago and chopped it up for a look, wish i'd paid more attention now!!
24th Nov, 2006 at 07:13:16pm
As spark plugs are designed to spark electrode to case the -ve pulse can give a slightly weaker spark because it goes case to electrode. not worth worrying about though.
24th Nov, 2006 at 07:40:15pm
Coil on plug is the way to go IMHO On 26th Oct, 2004 TurboDave16v said:
24th Nov, 2006 at 08:10:32pm
On 24th of Nov, 2006 at 07:40pm Mini Sprocket said:
Coil on plug is the way to go IMHO Why do you say that Sprocket? I think that they are a very neat and compact solution, but in my experience they do seem more prone to failure than a coilpack or even old-style single coil?
24th Nov, 2006 at 08:23:59pm
Coil on plug is the way to go IMHO Why do you say that Sprocket? I think that they are a very neat and compact solution, but in my experience they do seem more prone to failure than a coilpack or even old-style single coil? Some (VAG) have areputation for unreliability, but the ones on my old Legacy turbo are still going at 180,000 miles. I like them too, but the coil pack is good enough and more to the point cheap! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Nov, 2006 at 09:34:57pm
Old Legacy coils are prone to failure in their old age. The nose cracks, the rubber insulator gets damaged. These are COP systems, so all 4 will fire the same.
24th Nov, 2006 at 10:26:08pm
With coil on plug if one fails you still have three to get you to the finish at least. On 26th Oct, 2004 TurboDave16v said:
25th Nov, 2006 at 01:17:11am
LS1 coils are appearing everywhere. Factory fit coils, that have a huge reputaion for serious sparks. Built in ignitors too and very compact, which can be handy for some ecu's ( not when I built mine though lol...ended up using some cheapy Bosch coils instead ) 9.85 @ 145mph
