Home > A-Series EFI / Injection > NON rise and rate regulator.
I friend has asked me if the new injection mini have a NON rise and rate regulator, I have no idea.
MW
you mean the 2007 Bini???
no silly :), i would have posted on here if so*wink* No the last minis with injection, or any car that has them.
Rising rate
works the same as any modern injection system and your turbo reg *wink*
yes he wants a NON riseing rate.
for a carb???
to clarify, MPi reg is rising rate
Why on earth would you want a non manifold-refeenced regulator??? Very vey strange.
If that's what he wants though, all he needs to do is remove the hose from manifold to regulator, and it magically transforms to a non-referenced (ie non rising and non falling) regulator...
blown_imp
Member #: 598
Gaol
No i think what you looking for is a linear rate regulator yes? So 1psi of boost = 1more psi of fuel?
J
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off...
cheers, i have not idea what he wants for it, it's to do some thing on his skyline, but that's about all i know. I sheel pass on your good advice.
Factory fuel pressre regulators are non-rising rate.
Those FSE power boost valves are rising rate. They do not control to a constant pressure but allow it to rise at higher flows. Hence they lower the AFR at high flows and give a bit more power without re-mapping the engine.
It is best to use non-rising rate regulators with the likes of Megasquirt as they use VE to generate a flow through the injector based on a constant fuel pressure.
Edited by Paul S on 30th Nov, 2006.
A lot of modern cars use a static system, mostly dead ends where fuel pressure doesnt change.
The LS1 variants use a fixed 60psi setup, and some tuners, even boosted retain this for simplicity.
Obviously an ideal turbo setup will have a boost referenced regulator.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Stevie, surely that is only true for a carb'd system. An injected engine would be easier to map with a fixed pressure as previously stated ....... Had loads of fun once trying to help a mate set up his injected car with a referenced regulator .... How I didn't spot he had the wrong sort of reg on there until we'd wasted nearly an hour of RR time I don't know .. LOL
DOZ
Member #: 1089
You want a referenced regulator on an EFI turbo to up the fuel pressure with boost so you have a constant pressure differential across the injector.
If you had 20psi boost and 40psi fuel pressure you would only have 20psi differential across the injector, effectively 20psi fuel pressure/flow. Make sense?
Daniel
First 5-port EFI turbo in the world (built 1997, running in 1998)
Are you joking ???
Lets see you try and run 40psi of boost, using a fixed 45psi of fuel pressure.
Its not such an extreme example. You will end up with 5psi of usable fuel pressure.
Running a fixed FP in a boosted system, is totally stupid in my opinion and the wrong way to do it..
If they/you had trouble mapping the car due to a boost referenced regulator, I suggest you get somone else to map the car.
RogerM
Member #: 1217
Sorry ... not typing what I was thinking ........ Distracted here ... anybody want a dog???? LOL
You are of course correct, you need to reference but in 'fixed rate' which is what I meant to type (not just fixed).
Yes, you have to maintain a differential across the injector seat to maintain the correct atomisation properties of the nozzle.
Some of the big automotive corps. have played with rising rate regs and fuel pressure sensors as they potentially give you the advantage of a smoother map as the fuel pressure can rise faster than MAP negating the need to have a bit of an enrichment bump to cover the transision form NA to boosted, instead having the reg deal with the enrichment so the map can stay more linear. The problem is getting it all sorted for all loads / MAPs etc.
Petrol fuel injection is mostly still very primative in comparison to what the diesel boys get to play with. Even the modern direct injection engines are decades behind the equivelent diesel technology, mainly because the petrol engine is a little more tollerent due to having an ignition source timed independantly.
One day ... LOL
