Home > Technical Chat > valve stems wear
nogin
Member #: 487
westbury, wiltshire
just taken off me head to find lots of oily residue in the chambers and behind the valves, engine smoked a bit, the thing is that most people find it a problem with the inlets but i have lots of oil on the back side of the exhausts, litteraly coated, i can wiggle the valve in the guide about 1.5 mill, too much?
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I'd say so if I have understood you correctly.
If it's the original material guides then they are probably worn to death.
New guides aren't too bad to fit so long as you can drive them straight and take your time.
nogin
Member #: 487
westbury, wiltshire
well it is an original head with 90000 miles on it
i also make things
Well, it's the valve guides no doubt. If it's an unleaded head the valves are usually not worn on the stems. A+ valves are of fanstastic quality in terms of longetivity. Flow wise they can be improved.
If it's an older A head, you need to measure the stems with the correct equipment.
turbo hogster
Member #: 178
stowmaket suffolk
chuck some bronze ones in.
if you want i can supply you a valve guide setting tool and 9/32 reamer to do the job, then you just need to get your seats recut if they have original guides still in.
I've been using bronze only in the exhaust lately. The iron ones wear much better with chrome plated stems in my book. This means more miles with cheaper stuff to be honest.
nogin
Member #: 487
westbury, wiltshire
ordered a new head so should all be sorted but cheers
i also make things
