| Home > Help Needed / General Tech Chat > pulley | |||||||
78 Posts Member #: 1021 Advanced Member Portugal |
3rd Dec, 2006 at 01:43:56am
witch is the best way to remove the camshaf pulley.
3rd Dec, 2006 at 01:58:47am
2 screwdrivers works for me
3rd Dec, 2006 at 07:51:17am
Sometimes a good "wiggle" will do it, other times a three legged puller used carefully is required.
17th Dec, 2006 at 04:11:47am
Hi again, I want machine a crank pulley to use a megajolt, anyone have can tell me how many teeth that have, and other instruction to machine the pulley.
17th Dec, 2006 at 08:57:47am
why not get one from http://www.mini-pulleys.com Team www.sheepspeed.com Racing
567 Posts Member #: 102 Post Whore Pennsylvania USA |
17th Dec, 2006 at 01:11:23pm
PM tom fenton only 35 notes and weel worth it. |
17th Dec, 2006 at 05:42:43pm
yes toms pullys are superb!
17th Dec, 2006 at 07:50:31pm
Because I am from portugal |
17th Dec, 2006 at 10:24:23pm
but anyone have the blue prints to machine the pulley.
18th Dec, 2006 at 12:22:46am
Tom might be able to help you there.
18th Dec, 2006 at 12:44:40am
Missing tooth needs to be related to the sensor at 90 deg BTDC.
21st Jul, 2007 at 04:45:46pm
I buy a megajoilt, but I need my pulley manchined, I send a pm to Tom but he don't do pulley anymore, any one have some drawing with mesuares?
21st Jul, 2007 at 05:44:01pm
21st Jul, 2007 at 09:16:50pm
Thanks Mini13, very useful
Edited by QuimFintas on 21st Jul, 2007. |
22nd Jul, 2007 at 01:12:09am
anyone can tell me if a machine pulley with a tooth with a 1mm diference cause any problem?
22nd Jul, 2007 at 03:34:33pm
It should'nt make any difference,
On 26th of Oct, 2006 at 12:59pm mini13 said:
As minor63's pics show, the cut outs are machined into the outside of the S damper, and the damper bolts onto the pulley ( as per the original cooper S) heres the mini spares parts I used, http://www.minispares.com/Product.aspx?pid=36125 http://www.minispares.com/Product.aspx?pid=34237 also there's the vee belt pulley available. http://www.minispares.com/Product.aspx?pid=33426 Machining the pulley was actually pretty simple, bolt it to a indexed turntable on a mill and mill a chunk out every 10 degree's. then remove a tooth once you decide where the sensor will go. 63's pulley is a bit nicer with the square cut outs, I didn't trust works cheap mill not to grab if i had it set up verticaly, but even with my shallow crescent cut outs it still provides a good signal.
23rd Aug, 2007 at 04:01:58pm
Hi, I buy a megajolt and send the pulley to machine shop, but they tell me that the pulley isto no balend, 3mm.
23rd Aug, 2007 at 11:46:36pm
any can konows if I can use a 998 A+ (1990) in a metro turbo engine?
24th Aug, 2007 at 06:54:06am
Yes you can, but isn't that supposed to be identical?
25th Aug, 2007 at 12:43:14am
I send the pulley to machine shop and they call me, and say tha the puley is damage, in lateral sight the exterior have 3mm from center.
