| Home > Help Needed / General Tech Chat > Metro Ecu and bleed solenoid. | |||||||
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
4th Dec, 2006 at 08:52:56pm
Just used the search engine but to no avail, so sorry if covering old ground.
567 Posts Member #: 102 Post Whore Pennsylvania USA |
4th Dec, 2006 at 09:41:14pm
I use an adjustable boost valve. This way you can bleed off so you can achieve whatver PSI you want(within Reason). |
4th Dec, 2006 at 09:55:17pm
i have fitted a manual boost controller (MBC) to do a similar job.
Edited by MarkGTT on 5th Dec, 2006. |
4th Dec, 2006 at 11:04:17pm
Can appreciate why you use an MBC, but due to having bad experiences in the past with an in car MBC in a mates R5 (winding it out untill the knurled section comes off in your hand!!) and knowing what my urgew to fiddle is like I want to sway away from this, (same goes for mounting under the bonnet)
5th Dec, 2006 at 12:15:47am
IIRC the metro ecu pulsed the valve to give the required boost.
5th Dec, 2006 at 12:16:59am
P.S. you could always put the MB under bonnet so you couldn't reach it and plumb it in behind the sol' valve so that you could switch it but not fiddle ...... Every day is a school day ...........
![]() 341 Posts Member #: 259 Member grays, essex |
5th Dec, 2006 at 05:38:03pm
it may b small but it purfectly formed
5th Dec, 2006 at 05:57:34pm
Thats a good idea 1976_mini , as long as the metro solenoid doesn't resrict the boost when open, eg; say the mbc set to bleed a further 4 psi and the solenoid only allowing 3 psi bled.
5th Dec, 2006 at 06:00:44pm
are you sure thats how you plumb in a bleed valve?
5th Dec, 2006 at 06:01:45pm
last q was directed at 1976_mini btw "Turbo's make torque, and torque makes fun"
5th Dec, 2006 at 06:08:10pm
Think your right Joey.. |
5th Dec, 2006 at 06:15:05pm
just been sat mulling over what you chaps have said. as the solenoid is open untill powered up, (well the one I have sat infront of me is open unless its duff!!) could i have it wired off a switch on my dash and use this (ebay) Item number: 260059786540, to close it at whatever max boost i wish to run? eg, set the actuator to 6psi, use the solenoid to bleed at the flick of a switch, and the boost switch to shut it at 9Psi? How does that sound? also is the solenoid ok to stay energised (in the shut position) for long periods of time (as it would be to run the above mentioned set up, on "low boost" without killing it?
5th Dec, 2006 at 06:48:54pm
I really don't like the type of bleed valve suggested here, they tend to give a very soft edge boost curve. This is because to a certain extent they are always bleeding a little so the rise to normal actuator controlled level is slightly slower and thus feels less agressive if you get my drift.
5th Dec, 2006 at 06:49:01pm
his description reads right, but the labels on the diagram dont |
5th Dec, 2006 at 06:51:26pm
Oh yes, VW ones work well.
5th Dec, 2006 at 06:52:40pm
Have emerald |
5th Dec, 2006 at 06:57:12pm
it was the diagram that was throwing me "Turbo's make torque, and torque makes fun"
5th Dec, 2006 at 10:26:03pm
Hey joey, yea ian got it right the labells are wrong, it was a small pic when i up loaded it so i couldnt see the writing. It was an old pic i hosted a while ago when i was asking about plumbing it in! sorry for the confusion tho!
6th Dec, 2006 at 08:29:35am
The next question is should it plumb in to the actutor, was thinking of attaching it to the carb, which is where I found the solenoid, (fitted to the one i have sat in my shed) but after lookin in the haynes joke book last nite, and now not sure that the item sat infront of me is the solenoid, will try and post a pic this eve.
6th Dec, 2006 at 10:09:05am
The thing attached to the carb is an anti run on valve not a bleed valve.
6th Dec, 2006 at 06:45:26pm
This is what i have, if its the anti run on vavle does it stay shut (energised) when car is running, and opens to lean out, stall when ignition off? had a look on a mates metro this afternoon, he has a valve of sorts on the breather circuit, is this not the anti run on?
49 Posts Member #: 768 Member Fixing my car.... |
6th Dec, 2006 at 08:00:43pm
I was running an Apexi AVC-R boost controller on mine (not any more, had to sell it to buy parts....) It was the absolute tits.... better than any bleed valve or solenoid i have ever used before. |
