Home > Introduce Yourself > Hello all.....
modifiedminis
Member #: 768
Fixing my car....
I registered a while ago but forgot my password.... sorted it out now so here i am....
I was running a 1275 in my car untill i melted two pistons last eekend...ooops... for the time being it's a 1000cc turbo...
AL
Member #: 1347
Croydon (South London)
Modified minis, recognise your car from the pics, im the guy who bought your block off you. Its peter isnt it?
Ps show em your wheels *wink*
Yet more pistons to add to the collection lol
Edited by AL on 6th Dec, 2006.
modifiedminis
Member #: 768
Fixing my car....
Hi, yep it's Pete, howz the block?
i melted it properly...
Which wheels revo's or spe's?
modifiedminis
Member #: 768
Fixing my car....
Edited by modifiedminis on 6th Dec, 2006.
AL
Member #: 1347
Ouch, no messing about. Yeh blocks all good, still looking for some standard (non melted *tongue* ) pistons. The splitties, i love em.
HI and welcome
its a combination of too much boost and too high a compression ratio coupled with too lean a mixture which has killed the pistons
this is the fineist Example of detonation i have ever seen........WOW!*surprised*
you need to get clued up on this before it happens again for sure!!!!*wink**wink*
in the mean time i
*if you hear a ping....*frown*................ or pinking lift your foot*
Edited by BENROSS on 6th Dec, 2006.
Oh my god your sig is horrible! ha ha.
Welcome *wink*
AL
Member #: 1347
[quote=BENROSS,6th of Dec, 2006 at 09:03pm]
quote]
What was it - standard pistons, head and 1bar of boost?
modifiedminis
Member #: 768
Fixing my car....
On 6th of Dec, 2006 at 09:03pm BENROSS said:
HI and welcome
in the mean time i
Thats called driving it hard for 4 months with broken rings, piece of ring get stuck to piston, creates hotspot..... hence melted piston...
Yep it's running about 10:1 compression ration as the head was skimmed and 15 psi boost but i have been running it like that for 2.5 years and this is the first time i have done a piston like that.
I am running a/f ratio meter, it didn't lean out.
As for hearing pinking...hmmmm on a full s/c c/r box you can't hear a thing.... lol....
Bodge Job
Member #: 953
London
Edited by Bodge Job on 31st Mar, 2007.
Ric
Member #: 36
Basingstoke
you must have a mighty intercooler to run 14psi on 10:1!!!
and welcome. :)
Hello and welcome
modifiedminis
Member #: 768
Fixing my car....
and welcome. :)
I am running a 2wd cossy intercooler, with air charge temp guage... when it went it was runnin 19 degrees... so not hot....
On a 7 mile thrash (on a big straight road) holding it at 6000rpm and 20psi boost was only running 40 degrees so i think it's quite efficient
You ran 20psi on 10-1 compression, what octane fuel you running ? what ignition timing ?
18-20-degrees advance will probably reduce the detonation (and power lol) to run that kinda boost Phil :)
That does really look like it's been detonating for a long time - not just in the last few minutes of its life.
Hey - welcome all the same. Hopefully you'll find some ideas on making one that will be a little more suited to boost from a CR standpoint..... :)
modifiedminis
Member #: 768
Fixing my car....
I always run it on Shell Optimax or whatever it is now.... (never use tesco 99 Ron stuff)
I run the timing quite retarted.
I have got a new engine on the way but i got to finish paying for it first... so my 100k 1000cc engine with my turbo running 15psi at the moment to last me a few months......
T3Tone
Member #: 252
Sunny suffolk
Hello and welcome
-MINI CLUBMAN 1380 TURBO-
modifiedminis
Member #: 768
Fixing my car....
I have been sripping my old engine down today, got the pistons out my suspicions were right. The ring had broken on piston No 4, it has slowly worked it's way up the piston and out by the crown where it has been mangled about a piece has travelled back therough the inlet port into cylinder 3 where it has got stuck down the side of the piston and created a hotspot and melted a hole in it. The other pistons are fine. The one with the hole in it has got none of the normal signs of detonation, the pitting round the sides of the crown.
This is No4 piston that had the broken ring, you can see where it had slowly worked up and down in the piston untill it had broken through.
This is number 3 piston
Thou shalt never retart anything. Goes without saying!
Edited by Vegard on 28th Feb, 2007.
thats proper dead!
EssexSteve
Member #: 7029
Wickford Essex
pete are you in southend?
turbominivanman
Member #: 1504
Westbury, Wiltshire
Welcome to TM Pete.
Sorry to hear about the damage - looks to be proper knackered.
Are you gonna open up a build thread for the new un ?
Richard.
