Home > Technical Chat > Inlet Manifold heating
MrTurbo
Member #: 814
Utrecht, The Netherlands
Should I connect the inlet manifold cooling/heating pipes to the cooling system or not? I've seen a lot of pictures with the pipes cut off/not in use.
In my opinion connecting them up only heats the manifold (and thus heat the inlet charge) instead of cool it.
Of course the turbo is producing a lot of heat and sits underneath the inlet so it might be useful in the end.
Don't know what's best. Please help!
Nope, dont bother *smiley*
Not worth the effort in my opinion
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Yes conecting it up will heat the manifold (obviously to the temp of the coolant), it initially being intended to improve economy on NA cars by preventing fuel from dropping out of the inlet charge I believe. I guess it's not as useful anyway with the heat from the turbo underneath.
On 7th Nov, 2008 Nic said:
naeJ
m
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
The heating is there as BL obviously thought the cars would spend most of their time running around town off boost, probably correctly!
Of no use to use, even for a pure daily driver, leave them off.
Dangerous
Member #: 417
Mr Turbo lives in the netherlands,So I think he should have them connected if planning on going out in the cold.
Edited by Dangerous on 7th Dec, 2006.
If I am correct, the Netherlands is no colder than the UK?
I personally haven't bothered plumbing them in.
MrTurbo
Member #: 814
The Netherlands is just as cold as the UK, just a bit less rain..*wink*
If you think about the inlet charge temps you'll be seeing with no intercooler fitted, is it not a possibility that plumbing up the water connections will actually cool the manifold to some degree ?
Phil. *smiley*
JT
Member #: 637
Hertfordshire
thats what i was thinking phil, but if you have a intercooler then dont bother?
or am i thinking in the wrong way?
My build thread..
[quote=josh_tacon,8th of Dec, 2006 at 12:57am]thats what i was thinking phil, but if you have a intercooler then dont bother?
quote]
Correct ! *smiley*
