Home > Help Needed / General Tech Chat > heater
QuimFintas
Member #: 1021
Portugal
if I remove the heater what can T do to mists the widscreen?
Is good or not remove the heater
Ass; Daniel Machado
Star Mag
Member #: 375
Leicestershire
Use a bar towel works a treat for me!! *tongue*
Carl
Member #: 95
liverpool-on-sea
im gonna get a heated front sc reen in mine, at castle combe on the wet outing i had a major problem with misting. and couldnt reach the screen to wipe due to harness!
i did get some anti mist stuff thats designed for motoebike visors which helped
JT
Member #: 637
Hertfordshire
how much are heated front screens then??
that sounds like a plan!!
My build thread..
slater
Member #: 1291
Suffolk / Birmingham
Your allright as long as you keep the window open. I dont relly find it an issue! well not as much as the useless windscreen wipers :)
jamesfawcett
Member #: 218
Bingley, West Yorkshire
are you alloud windows open on a track day? i remember when drag stripping mine at york they told me to put windows up
Carl
Member #: 95
liverpool-on-sea
no they dont let you have the windowes open. i opened um a tiny bit but it didnt help
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Not used them yet but going to try a screen from these people when I build my car.
http://www.heatedwindscreen.com/acatalog/H...indscreens.html
They do both the old school works style ones and modern ones.
diddy
Member #: 505
Stockton-on-Tees
If you're removing the heater because you've fitted a turbo bulkhead box and don't want the original sticking out, try using a van heater, i have one in mine and it works a treat. It ain't as sophisticated as the saloon heaters, its got a springy metal flap that decides whether you heat the car or the screen, but its small and does the business of keeping the screen clear
QuimFintas
Member #: 1021
Portugal
No problem I will use a hair drier, lol,
I don“t like the heater
RogerM
Member #: 1217
Anybody found a heater from another car that is small and compact enough to be used in a road car??????
Minimad69
Member #: 1311
Yeovil, Somerset
what about using the original element from the existing heater matrix and making your own housing for it with a couple PC 12V electric fans to circulate the hot air
slater
Member #: 1291
The biggest problem i have with my car is the lack of ventelation due to blocking off the top vents aswell as the heater vent so make sure you keep those!
RogerM
Member #: 1217
I'm aware of that ... LOL Once built a race car with no vents and fixed poly windows, except the normal sliding vent in the drivers window. Couldn't see a thing in the car after about 5 mins!!!
No chance of binning the heater in this build, if anything I need a better heater as my better half is from South Africa and shall we say, feels the cold a little!!!
pot_dan
Member #: 326
bradford, west yorks
i was looking at possible options and looked into the ceramic car heaters but even the people actually selling them on ebay say their not right much good, lol
will look out for a van heater i think, sure i remember reading about someone modifiying the origional one into a smaller casing or something but cant remember where now..
http://turbominis.co.uk/car/105/
evolotion
Member #: 83
Glasgow, Scotland
look on computer forums and shops for water cooling setups, and look at the radiators fans and ducting . could make somethign useable outa them bits! or a PC fan, your old heater core and some flexible ductig from B&Q
Denis O'Brien.
t3gav
Member #: 229
Gavin@minispares.com
kent
Heated screen sounds like a good idea, the little wires annoy me though!
QuimFintas
Member #: 1021
Portugal
If I modify this heater to fit the tube is a good option?
http://cgi.ebay.co.uk/CERAMIC-WARMER-CAR-H...1QQcmdZViewItem
Ass; Daniel Machado
i got my screen from www.gi24.com or co.uk/.net
cheapest place i found and very quick
QuimFintas
Member #: 1021
Portugal
the web site is temporarily closed, can you tell me how many you pay?
Ass; Daniel Machado
i cant remember i got it 4 years ago www.minispares.co.uk have them too, but they were more expensive
the montecarlo is only different as it has the foil showing like the old rally cars, the other styles are not immediately noticable
