| Home > General Chat > Plenum Chamber Bolts | |||||||
8th Dec, 2006 at 10:34:07pm
If I recall correctly there were a few posts about people having trouble sourcing plenum chamber bolts.
8th Dec, 2006 at 10:57:33pm
I used bolts, nuts and washers with the holes drilled out |
8th Dec, 2006 at 11:03:32pm
Hey you shouldn't use metric stuff on you bored out 1275CC engine,with the M18 fine sparkplug threads.
Edited by Dangerous on 8th Dec, 2006.
9th Dec, 2006 at 05:37:40am
diff housing studs/bolts |
397 Posts Member #: 694 Senior Member Shropshire |
9th Dec, 2006 at 04:36:43pm
Silly questionb but arte you refering to the bolts which pass through the Plenum Chamber and connect to the carb or the ones which connect the Plenum Chamber to the elephants trunk? |
9th Dec, 2006 at 04:42:19pm
These are the bolts that connect the plenum to the carb. Isambard Kingdom Brunel said:
Who's going to moan first?!? lol!
