Home > Help Needed / General Tech Chat > layshaft 22A 1737
JT
Member #: 637
Hertfordshire
hi
done a search but couldnt find anything
does the number in the topic mean anything to you? (22A1737)
its in a gearbox im thinking of buying.
im just trying to find out weather or not its stright cut, close ratio type box or just stight cut.
all i know is its pre a+ gears in a a+ box, and its stcight cut!
any info would be good.
edit: the bloke told me the first gear has 22 teeth.
cheers
josh
Edited by JT on 10th Dec, 2006.
My build thread..
neilj1678
Member #: 1297
Sunny Stockport
Straight cut original ST ratios according to Minispares:
http://www.minispares.com/Product.aspx?pid=36119
JT
Member #: 637
Hertfordshire
cheers mate iv just found it myself.
would this set work ok in a A+ box even though the gears are pre A+?
i think i will need a A+ reverse gear but the rest should fit ok?
cheers
josh
My build thread..
Just use an A layshaft and you'll be OK. This fits easily in an A+ box.
You'll need the proper ST reverse gear with this, and that is similar in A and A+ form.
JT
Member #: 637
Hertfordshire
so i would need to get a proper ST revers gear? i couldnt just use one out of my A+ 998 box?
i take it these gears are still availible for puches but there just out of stock atm?
cheers
josh
My build thread..
