Home > 998cc > 998 T2 fuel return
iamhata
Member #: 1093
can i run without the charcoal canister and use the fuel tank breather for fuel return
thanks
Ben H
Member #: 184
Melton Mowbray, Pie Country
Not advisable to run without a fuel filter.
Also you need a breather in the tank, althought the mini tank filler is never a good seal. You don't need a return to the tank though. Bud666 has plumbed his return into a T piece between the tank and the pump inlet and as far as I know it works fine.
http://www.twin-turbo.co.uk
iamhata
Member #: 1093
if i use a t piece as a return, will the fuel pump suck the fuel and "air" from the return line??
what air?
iamhata
Member #: 1093
i am not sure , i guess there will be some air from the return line, when the fuel return from the fuel regulater, such as the return line has less pressure than supply line . sorry for asking a lot of question,
thanks
There will be no air. Just fuel at low pressure.
sorry, didnt mean to sound abrupt
i would think that after start-up all the air will be pushes out of the return line, so i wouldnt worry about it.
Also, the gueltank breather is not of sufficient diameter for a return.
As above, use a T-piece on the tank side of the pump.
