| Home > Help Needed / General Tech Chat > compression ratio? long post | |||||||
12th Dec, 2006 at 12:24:35pm
I know some that are using/have used very low c/r to prevent detonation under high boost.
12th Dec, 2006 at 01:29:28pm
well its a hard answer fab .. but this is mine,,, all the top motors run an average of 8.2:1 cr
12th Dec, 2006 at 05:12:28pm
fab , one thing to do is make sure on your low cr engine ,that you have enough ignition timing on it ,especially below max boost,
Edited by robert on 12th Dec, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Dec, 2006 at 06:36:21pm
On 12th of Dec, 2006 at 05:12pm robert said:
an alternative is a knock sensor induced water alcohol injection ,which is my present fave idea. regards robert The idea of that may sound good. But IMO, it would be far too slow to respond, to rely on it for engine safety. For tcord, I ran mine at 1.5 bar boost, 7.5:1 CR, std size chambers ( std with a little clean up, NO shape alterations ) and a welded dizzy at around 24-28 deg. Cant rem for sure. it was slow to build boost down low ( fuelling could be improved, and it is a relatively big turbo ), but it was also incredibly torquey, running on 4 star pertrol !!!! its that long ago lol Next time around, I think I'll be aiming for mid-8's or maybe low 8's at a push. 9.85 @ 145mph
12th Dec, 2006 at 07:02:31pm
well
12th Dec, 2006 at 07:23:51pm
Incidentally fab, my cr is 8.27:1 Edited by BENROSS on 12th Dec, 2006.
13th Dec, 2006 at 09:09:53am
well mine is a high cr med boost motor last year i ran 9.4 cr dizzy fixed to 27 deg 276 cam and could run 12 psi with no det at all or 14 psi with a hint of det at 4000 rpm.
13th Dec, 2006 at 11:44:33am
Mine engine has a cr of about 7.9:1 but again it is a 1380. It pulls without hesitation. A 1275 is most likely totally another issue. I have retained the vacuum advance. Disconnect it and the 1380 will feel lazy at low revs. |
13th Dec, 2006 at 01:51:04pm
WHat total iginiton advance where you running FAB?
AlexF |
13th Dec, 2006 at 05:42:34pm
dizzy was set at 7° , corretc if I'm wrong but the total dizzy adv was 18° so it were about 25° total |
