| Home > Help Needed / General Tech Chat > More info needed on a TB0223 / 466770-3 turbo | |||||||
15th Dec, 2006 at 07:17:01am
Can anybody give me any more information on this turbo?
15th Dec, 2006 at 07:20:11am
i'm guessing its from a montego turbo diesel then? If so i have one the same with no cracks etc but decided it looked a bit small for what i wanted |
15th Dec, 2006 at 12:58:05pm
Ian, does look a little small next to metty T3.
15th Dec, 2006 at 02:02:48pm
This website has the best info on what turbos are fitted to what cars:
15th Dec, 2006 at 03:09:16pm
I believe this is a 50-trim compressor? If so - it's the same as the R5GT turbocharger. You won't find a less-laggy turbo or one that falls so neatly in the sweet-spot at 12psi anywhere else.
15th Dec, 2006 at 04:52:18pm
I guess I am going to have to strip it and measure the turbine to make sure .... Every day is a school day ...........
15th Dec, 2006 at 05:11:45pm
Hmmm - seems this might be a 60-trim compressor!
15th Dec, 2006 at 06:15:28pm
Will do Dave, not sure when though ... LOL.
15th Dec, 2006 at 06:16:10pm
Where did you get your info that suggested 60 trim Dave??? Every day is a school day ...........
15th Dec, 2006 at 06:22:49pm
A polish spreadsheet I found on the internet a few years ago...
15th Dec, 2006 at 07:03:23pm
Please share ... .please .... Every day is a school day ...........
15th Dec, 2006 at 07:16:54pm
"I am looking for low lag and 12 psi max ... only thing that concerns me is that it might strangle to engine at the top end"
15th Dec, 2006 at 07:51:35pm
Shame .... can't seem to find a decent T2 from an R5GT ... like a gold plated hens tooth in a pile of rocking horse poo it would seem :( Every day is a school day ...........
15th Dec, 2006 at 08:08:57pm
This would definately be a good unit for a higher revving engine; but at that point the exhaust turbine would probably be a little restrictive - so you'd lose out...
15th Dec, 2006 at 08:32:05pm
how 's your turbine hsg?no crack?
Edited by fab on 15th Dec, 2006. |
15th Dec, 2006 at 08:54:45pm
Fab,
16th Dec, 2006 at 08:39:13pm
roger , its a 1988 montego or 89 meastro or montego 2 litre diesel turbo , as dave says a 60 trim comp , and it has a .8 to .87 bar wastegate on it this pressure should give .38mm rod movement so id expect it to give a touch more in running say .95 bar , its a .35 a/r turbine housing ..the part no for the wheel on the turbine side i couldnt find , but i d imagine it would be quite small ,as the only specs on the 2 litre monty are for 80 bhp , which is a low revving high low down boost sort of engine i think .but i may be wrong on the power .
17th Dec, 2006 at 02:00:39pm
Cheers Robert.
17th Dec, 2006 at 04:00:41pm
should def do that for you Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
