| Home > Help Needed / General Tech Chat > Is this something to worry about? cracked valve seat. | |||||||
17th Dec, 2006 at 06:45:17pm
Sripped the valves out of the Ex works Group A head and found that #1 and #4 inlet valve seats are cracked On 26th Oct, 2004 TurboDave16v said:
17th Dec, 2006 at 07:09:39pm
When I first had the larger exhaust valves fitted to a turbo head way back in 94, I had already noticed very minor cracking.
Edited by stevieturbo on 17th Dec, 2006. 9.85 @ 145mph
18th Dec, 2006 at 02:53:57pm
my opinions the same as stevies, but........
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
18th Dec, 2006 at 04:14:00pm
I can tell you that although they are small, they will cause you a ballache later on. They will grow and eventually you'll have a water ingress problem and if left you'll end up with poor compression. You can repair cracked heads, but unless its an expensive/rare one its not worth it. I've seen the future and tbh its Pie
18th Dec, 2006 at 04:15:26pm
But what's the worst that can happen? The water-jacket is a long way back - I'd have theought you'd lose compression before it hits that?
18th Dec, 2006 at 04:49:48pm
should be ok but just remember that the exhaust insert could drop which could be pretty ugly none that before , ask t3tone he has a near miss on these. always looking for them bigger bunches of bannanas |
18th Dec, 2006 at 06:19:28pm
Its a pity I still dont have that head or I'd take some pics. Pretty sure I threw it out when I moved house 3 years ago.
18th Dec, 2006 at 07:19:02pm
Well Im gonna run it, see what i can get out of the engine now with it on.
19th Dec, 2006 at 08:20:53am
I would not use it as the valve seat might loosen or worse fall out. What heppens then is anyones guess. Have the inlet valve seat machined down, and fit an insert there as well. The exhaust needs to go and a new one fitted there as well. SO:
19th Dec, 2006 at 10:04:28am
I used to have a MG1300 when I was a little boy (that´s before some of you were still safely tucked inside daddy´s groin). The original head had a cracked head (between in and ex) that I ran for a couple of years. No inserts though. Apart from slight loss of coolant there were no ill effects. I am not sure if the loss of coolant was in fact related to the cracked head. Anyway, as far as there are no apparent loss of power just run it. The only issue is that if the insert has cracked through the complete cross section it may eventually come loose. But you will cetainly notice if it happens... |
19th Dec, 2006 at 07:16:15pm
On 18th of Dec, 2006 at 07:19pm Mini Sprocket said:
I thought the same about the possability of the valve seat dropping out. If it happens it happens. Its all in the fun. Thanks for the advice Ive had a valve seat drop before. there is nothing fun about it. An entire Rover V8 engine, and both turbochargers destroyed. While an interesting engineering/mechnical excersize, it was not one bit fun. 9.85 @ 145mph
19th Dec, 2006 at 07:18:53pm
On 19th of Dec, 2006 at 07:16pm stevieturbo said:
While an interesting engineering/mechnical excersize, it was not one bit fun. Amen to that........
19th Dec, 2006 at 10:57:47pm
Well, we all look at things in different ways.
19th Dec, 2006 at 11:40:14pm
That cost me around £5-6k maybe a little more.
20th Dec, 2006 at 12:32:04am
I know where your coming from and if it were an engine as you say cost £KKKK's then i wouldnt take the risk, my pocket isnt that deep, but when you take risks, you have to accept the concequencies. Edited by Sprocket on 20th Dec, 2006. On 26th Oct, 2004 TurboDave16v said:
20th Dec, 2006 at 08:48:19am
Why not have the thing sorted while it's all off? Two seats including job here in Norway would be around the £100 mark.
