Home > Help Needed / General Tech Chat > Turbo nose bearing, Damn....
Turbo Tel
Member #: 588
Delaware, USA
I read it a hundred times but still did not comprehend...
I never really sussed out just which bearing was the "Turbo nose bearing" and I dismantled both of my gearboxes , one Turbo one normal. When I saw the little cage type bearing right at the front that looked nothing like the nose bearing piccy on the minispares site I just snapped it off and pulled the remains off with a puller just a cheap cage bearing I thought....
DAMN!!
That was it!! the rest of it was still in the bloody transfer casing --- a 35 quid mistake cos I didnt read the posts properly and thought it was in the gearbox casing, not the TRANSFER casing..
Stupid Terry
If it's already sent one metro to the junkyard, it needs changing anyway. :)
Folks have managed with the standard bearing just fine before now; guess it depends what you want to do.
Turbo Tel
Member #: 588
Delaware, USA
My standard transfer casing is slightly damaged near the starter, so I want to use the turbo one, I'll have to stump up..
For anyone else that cant read, The broken thing sitting on the end of the input gear is the turbo nose bearing....
Oopsie *frown*
RTFM*wink*
Edited by Sprocket on 18th Dec, 2006.
paneermeel
Member #: 1404
The Netherlands
same here*tongue*
but thanx to this forum now i know.
but if the bearing is different does this mean the casing is differant???
or aslong you replace the whole bearing it fits a normal or turbo casing?
there is nothing wrong with a A-series that a turbo can't fix.
www.turbomini.nl
Turbo Tel
Member #: 588
Delaware, USA
Yup
The Turbo transfer casing has a bigger hole for the nose bearing so you have to use the appropriate bearing for whichever casing you use, but I believe they can be swapped, i.e its OK to use a normal transfer casing with a Turbo engine.
Terry
paneermeel
Member #: 1404
The Netherlands
well i don't have a turbo casing so a standerd item will do.
thanx for the info
www.turbomini.nl
paneermeel
Member #: 1404
The Netherlands
i got my new bearings for the gearbox rebuild :cool:
but now the question is which type of bearing did i get. i seems to be the same as i already got. so i will fitt. but i dont know for sure is it turbo or non-turbo????
it's a RHP 2/LRJ15.8
if someone could tell which one it is i know a little more about mine engine's tranfer casing. (turbo or standerd)
www.turbomini.nl
paneermeel
Member #: 1404
The Netherlands
this must be it.
http://www.minispares.com/Product.aspx?pid=32830
google didnt work but minispares did.
i will leave it here for futere searches.
www.turbomini.nl
The 2/LRJ15.8 part number is the turbo type unless I am mistaken.
