| Home > Help Needed / General Tech Chat > N/A pistons for turbo applications. | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
20th Dec, 2006 at 12:53:21pm
ok while my quest continues ie saving up for some nice pistons (IT 8NT GONNA HAPPEN), i have 4 or 5 built n/a blocks lying around all in good nick. can these be used safely with a turbo ? what is max boost that can be safely run, with turbo head using 28cc chambers and a 4wd cosworth intercooler. and what is the average CR when using N/A pistons ?
Edited by Richie on 20th Dec, 2006.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
20th Dec, 2006 at 02:02:20pm
i've been using N/A pistons in mine for 2 years, mine are the 21253's with 11cc machined into em. I think Nic was running them before he went all bling aswell On 20th Oct, 2015 Tom Fenton said:
20th Dec, 2006 at 02:20:17pm
Omegas for instance are totally similar when it comes to turbo or N/A. The only difference is the size of the dish.
20th Dec, 2006 at 02:49:00pm
i'm with Vegard on this one.
20th Dec, 2006 at 07:09:25pm
i think another thing that deff comes into it is heat soak , if you can keep on the throttle for a few mins at max boost without backing off ,thats quite likely to melt something , but the likelyhood of that is rare , so the typical on off type usage a high boost mini gets gives a window of usage you wouldnt have if it was a heavy car with a greater need for long on throttle situations . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
20th Dec, 2006 at 10:01:25pm
well i will give it a go :) will get some new rings for em and use em with me phase 2 etc. cheers for the replies guys.
20th Dec, 2006 at 10:08:11pm
On 20th of Dec, 2006 at 02:02pm bud666 said:
I think Nic was running them before he went all bling aswell yeah i was (i only changed them due to an unfortunate incident that allowed me a cheap upgrade), i ran 16psi on them, accidently ran 22psi once id pop them in and get it running, im sure you'll be ok on them once you get it all ok, if your feeling really keen and flush then you could upgrade to some other 'bling' jobbies |
21st Dec, 2006 at 04:14:44pm
had a look at em today, i have a clean set on rods, i have just had me crank pollished and have new shells etc etc. I am right in thinking i can use the rods with the pistons and just put em in with me new shells, or will i need to use the origional rods from me turbo ? they are both the same component ?
21st Dec, 2006 at 04:31:34pm
the 73.5mm powermax's look like they might be good, the top ring is a good way down. On 28th Aug, 2011 Kean said:
21st Dec, 2006 at 04:45:57pm
its still alot of money bud :) i got some s rods jacked up and a strked GT crank, but iam saving that back for the mega build. i just want to get me car done, all me moolar is going into painting it.
