| Home > Technical Chat > UJ's for gearchange | |||||||
28th Dec, 2006 at 08:52:27pm
Where can i find the UJ's to convert my gearchange to inside the cabin.
28th Dec, 2006 at 09:27:10pm
Rally Design, Demon Tweeks, Merlin Motorsport
On 5th Sep, 2011 Vegard said:
28th Dec, 2006 at 11:04:13pm
get the sealed ones, more money but hassle free "Turbo's make torque, and torque makes fun"
29th Dec, 2006 at 02:02:16am
when you pop over my place i'll show you where, |
29th Dec, 2006 at 02:02:50am
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
29th Dec, 2006 at 03:46:57pm
Could you use a couple of steering column ones? like.....
Edited by AL on 29th Dec, 2006. |
29th Dec, 2006 at 09:02:45pm
On 29th of Dec, 2006 at 03:46pm AL said:
Could you use a couple of steering column ones? like..... http://cgi.ebay.co.uk/BRAND-NEW-STEERING-U...1QQcmdZViewItem or maybe 1 of these? http://cgi.ebay.co.uk/PUNTO-MKI-STEERING-C...VQQcmdZViewItem Different kind of load on a gearchange - won't think they would be upto job for long On 5th Sep, 2011 Vegard said:
29th Dec, 2006 at 11:05:29pm
Sorry????
Edited by Sprocket on 29th Dec, 2006. On 26th Oct, 2004 TurboDave16v said:
29th Dec, 2006 at 11:08:15pm
I agree with Nick. Steering column joints are designed to work in rotation only. They are not designed to take any axial loads as would be required in a gear linkage.
29th Dec, 2006 at 11:09:33pm
i concur "Turbo's make torque, and torque makes fun"
30th Dec, 2006 at 01:33:03am
I think you are both right .... it will be subject to different loads but it isn't unusable if a good joint. All depends on the movement at the pins of the joint. I have seen some joints that are similar to a captive CV ... they would be great ... if a little over the top.
31st Dec, 2006 at 06:56:01am
Anyone driven an old Mini with a sloppy gearchange ? Any decent steering UJ joint will be better and will last for a long time. What kind of loads do you get when changing gears ???? |
31st Dec, 2006 at 11:08:53am
I think that so long as the engine doesn't move too much a steering joint would do fine. However that said I normally run with the standard tie-bar mount, one either side from engine to front member of front frame and ultimate mount and still have movement in the engine from the torque reaction.
31st Dec, 2006 at 11:26:41am
Ive seen folk use ones out of socket sets! Just make either the uj or the link to fit and weld it on!
31st Dec, 2006 at 03:54:03pm
socket set ujs are a bad idea, you certainly wont drill and tap for a grub screw ,and welding the chrome moly is always going to be poor practice,
Edited by fastcarl on 31st Dec, 2006. |
