| Home > General Chat > What are the chances !!!? | |||||||
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
29th Dec, 2006 at 06:30:51pm
well after a rumble around the garage looking for potential pistons i un earth'd a block from the deepest realms of "the corner", and out of curiosity thought i would slip a piston out and have a look so i could compare it the other pistons from blocks that i had (obviously to pick the best ones) as i looked closer i noticed it was totally different to the others i had, and on closer inspection i noticed the numbers 28013 which sure enough is MG metty turbo !!! i cant remember why i took the engine out at the time, but i recall one of them i was having issues with oil pressure.
Edited by Richie on 29th Dec, 2006.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
29th Dec, 2006 at 06:32:36pm
Depends on what size your block it at, and the same for the pistons too.
29th Dec, 2006 at 06:33:47pm
tom the piston is exactly same as ones i took out, it just has rings on, the rings have STD on so i presume they are standard ?
29th Dec, 2006 at 06:35:27pm
Measure them up to be sure, but if they are standard size pistons then putting them into a standard sized honed block should be OK as long as the hone has not removed too much material. I'd recommend checking ring gaps to make sure.
29th Dec, 2006 at 06:39:05pm
ok will d cheers tom. the block litterally was de glazed so microscopic amount of material will be removed, with regards to ring gap, what is the correct gap for this ringset ? i dont have my haynes book to hand.
29th Dec, 2006 at 07:44:44pm
ok the piston slides into the bore nicely and the rings hold it in place. i have gapped the top ring by taking it off the piston sliding into the bore, then squaring it up with the top of the piston (if you know what i mean) and the gap is 13 thou (i think it took a number 10 and number 3 on me old feeler gauges)
29th Dec, 2006 at 08:03:19pm
you can get new rings for these pistons you know, not expensive from MSC.
29th Dec, 2006 at 08:09:05pm
i have tried everywhere and i have been told the ringset is obsolete
29th Dec, 2006 at 09:04:21pm
sorry my mistake ,i thought they were NA, MG pistons. are the top two rings the same thickness as the slipper piston?? Edited by fastcarl on 29th Dec, 2006. |
29th Dec, 2006 at 09:08:36pm
nope they are marginally different :( this is why i as going to put the turbo pistons into me new block, well that was the idea anyway until i can afford some bling ones.
29th Dec, 2006 at 10:45:23pm
Measure the ring dimensions as acurately as you can and give these guys a call http://www.performanceunlimited.co.uk/Contents.htm
Edited by Sprocket on 29th Dec, 2006. On 26th Oct, 2004 TurboDave16v said:
30th Dec, 2006 at 01:29:16am
Just looked at the Total Seal catalogue and they list the Metro turbo 'Gapless' ringsets in std, 20, 30, 40,
