| Home > Help Needed / General Tech Chat > red dot doughnuts | |||||||
31st Dec, 2006 at 03:48:46pm
:) Edited by t3gav on 29th Feb, 2008. |
31st Dec, 2006 at 04:09:13pm
I had to modify my hi-los to get the car low enough.
![]() 568 Posts Member #: 1200 Post Whore Bristol |
31st Dec, 2006 at 05:01:07pm
ive fitted a set on mine and have wound the hi-los right down, hopefully once the engine is plumbed in and i get it out on the road they will settle down. |
2nd Jan, 2007 at 08:43:18pm
3rd Jan, 2007 at 12:13:21pm
You need to remove material on the adjuster end, but you'll also need to remove material from the big bolt. If not it will stop on the cone when fully wound in.
3rd Jan, 2007 at 12:53:10pm
Just as a point of reference the Ratio of metal removal to suspension height change is 1:3 at the front and 1:5 at the rear. It's slightly different at the front if you use Hydrolastic top arms but I don't know what the change is.
Edited by danboy on 3rd Jan, 2007. |
![]() 70 Posts Member #: 854 Advanced Member Fareham, Hampshire |
3rd Jan, 2007 at 07:09:52pm
Where is the best place to buy red dot doughnuts?
