Home > Wanted > actuator and few bits needed
mickeyturbo
Member #: 1212
braintree, essex
need an actuator for a mirage set up good for up to 10psi.
also need gaskets for a mirage set up (exhaust and turbo to manifold) pm me please.
you can use any actuator and bleed valve, you just need to relocate it
as for gaskets either try aet 01924 894171, or ebay (where you will save some money)
I've got a spare T2 actuator somewhere, which you can have. Also Mirage sell the gaskets, so it's probably worth giving them a shout.
Edit, just measured the actuator with a foot pump and it's 10 PSI. Also it's got two connects being off a Renault 5, as far as I'm aware you just need to block off the bottom one.
Edited by Rob H on 31st Dec, 2006.
mickeyturbo
Member #: 1212
braintree, essex
the actuator i got with the turbo from mirage... can i use that one? i couldnt work out how to locate it via a bracket. will the actuator u have be able to be set so i can run up to 10psi as i really only want 8psi for everyday driving and 10psi for fun times.
That's probably the same one as I've got going spare.
There are a few options out there if you do a bit of searching, I think FeebleUK used a Renault 5 actuator with his set up.
Sorry but it's only the standard Renault 5 item which came with my turbo, so it's not adjustable.
