Home > General Chat > SuperUnleaded,Leaded, LRP, Avaition fuel
b12
Member #: 247
Kent/Surrey Borders
well mines a 1989 MetRoTurboEngine
Gotta be superunleaded and an addative dont you think ?
What do you lot use ?
Steve
TurboLessTosser
Optimax with CVL - 101 octane.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
as he says!
alex
AlexF
i ran optimax and castrol additive with added octane booster. There are 2 different ones, just thought the one with octane booster should be a benefit!
Might see what av gas does though....
Castrol valvemaster is the stuff i was thinking of!
Edited by iain on 7th May, 2004.
Avgas is only 100 Octane.
I always thought Avgas was 108...
PaulM
Member #: 206
Isnt Lpg 108?
9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked
Ha Ha Ha, who told you that? No, LPG is around 95, definatley not 108!
Avgas that is generally available is around 100 octane. I think there were higher octane types about but they're hard to get hold of now.
Wil
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
avgas also burns slowly...
not good in a turbo engine!
alex
AlexF
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I use the optimax stuff, with some castrol aditive (the type with the added valve boost or something)
Learn something every day *smiley*
bet interesting to do a power run on a few different fuels and see what the difference is.
higher octane fuels don't directly give you more power, they simply give you the abilty of running more boost before det sets in.
Hedgemonkey
Member #: 360
So, higher effective CR=greater thermal efficiency=more power.
Tetraboost is the stuff you want, You can make your own avgas. Sadly, premium has Benzene added to it (in part) which increases the octane of the fuel by a few points, catch is that it kills your lead response. So, in order to make a avgas, you need Tetraboost (Lead) along with petrol containing no Benzene. LRP used to be good but that horrible filth they put in it was not worth bothering with. I personally will try and stick to stuff running valvemaster with 98 premium. Avgas might be worth a look, especially as it should have no road duty, but will be pricey to start. Avgas used to be available in 160 octane whichy used 4% TEL they backed this off to about 0.7% I believe which gives you about 100 (depending on what they were using as stock). You could try adding tetraboost to it. There are all sorts of ways of getting better fuel including paint stripper, acetone, etc, etc.
If anyone's really interested in the ins and outs of fuels/leading/additives, give me a shout. stu
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
maybe a nice drop of tolulene!
alex
AlexF
