Home > Help Needed / General Tech Chat > Clutch goes Eaaaaarrrrrrrrrrp !
Dangerous
Member #: 417
currently using a AP racing CP2599-4 plate,like this
With new grey cover and release bearing,steel ultralight and billet back plate.
Every time I try pulling away gently i.e less than 3000 rpm I get a large Eaarpp noise.If I let it out at 4000rpm I leave a lot of rubber.
Strange thing is it has been in and out a few times now and don't make the noise for a day or so after fitting.
Any ideas as I would like to venture into town sometimes,but getting stuck in traffic ould be a bit :$
un even wear i guess!
i would change it bri for a minispares race plate
problem solved
turbo daves the guru on clutches
You should hear a amtes Subaru that runs an iron faced disk !!!
Screach every time it takes up the drive !!!!
Dangerous
Member #: 417
Like this one,
www.minispares.com/Product.aspx?pid=35698
also the sintered plate could be why my primary bushes dont last long,too much heat transfer
Edited by Dangerous on 2nd Jan, 2007.
sounds normal to me,
carl
Turbo Shed
Member #: 30
Epsom, Surrey
i've never tried your plate but it could be the primary gear bush fretting on the crank. mine did and it screached like mad when slipping the clutch to pull away. i put a bit of grease on the crank and all is well now.
thats the fellow bri
like turbo shed quoted it could!! .........be the primary gear bush
as you have had some pain with it
I had another incident with noise once on my car...
The strangest chirping noise Id ever heard.
Turned out the bolts that hold the crank flange to the cover werent as tight as they could be....
it could be the bush, but i still say that noise is normal with that types of plate, i use them and when i had silencers i could hear mine too,
carl
Edited by fastcarl on 2nd Jan, 2007.
yeah i had one in a full race 1293 and it sounded exactly the same. never had any other problems barr the thrusts giving up *happy*
I run this clutch plate and get this noise too.
get that new plate then bri
