| Home > Help Needed / General Tech Chat > Tolerances of rebuilt box | |||||||
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
6th Jan, 2007 at 12:30:57pm
I have just rebuilt a 4 synchro remote box with new bearings, straight cut gears and mainshaft etc. The mainshaft is fitted to the casing and not yet fully torqued up as I am still checking everything. 1st and 2nd gear spin freely on the mainshaft with aprox 5-10 thou side to side play. My concern is 3rd and 4th gears. The gears have no play side to side at all. The baulk rings are up close to both of these gears which is preventing them spinning as freely as the other two gears.
6th Jan, 2007 at 12:59:15pm
dont run it like that, i made the mistake last year and had to buy a new 4th gear
6th Jan, 2007 at 04:49:10pm
Your ring is over-hanging the front of the gear as Nic points out. I never used to have this the first two times i built a box, then it occasionally started happening, in my case it was bogus rings... It could also be down to the gears having a synchro cone gauge diameter either on the limitof upper tolerance, or indeed over tolerance.
Edited by turbodave16v on 6th Jan, 2007. On 17th Nov, 2014 Tom Fenton said:
6th Jan, 2007 at 06:02:30pm
I have now torqued up the 1st motion shaft nut and the pinion nut and lubricated the hubs a little. The box has now loosened up nicely. 3rd/ 4th gears now have a little sideplay when the box is in neutral. I can see that the baulk rings are just clear of the 3rd/ 4th gear hubs with the box in neutral. Will this now be acceptable to run. I don't want to knacker anything.
7th Jan, 2007 at 08:58:49am
ist lesson lernt there, never panick until you have done up both nuts as this the pulls the main and first motion shaft apart given you the clearance, 1st , 2nd and 3rd gear should have much side ways movement but may have a little if you try and twist it, but be carefull to much will wear out the gear teeth on the gear and the correwsponding laygear teeth. always looking for them bigger bunches of bannanas |
7th Jan, 2007 at 03:11:47pm
Thanks for the info. This type of stuff aint covered in the Haynes manual. It's my first gearbox build, I don't have another to compare it with so I'm erring on the side of caution. |
7th Jan, 2007 at 06:53:48pm
I've had the same happen as well. Use 2nd had rings as adviced. On 13th Jul, 2012 Ben H said:
