Home > General Chat > Green paint
shane
Member #: 1246
Lowestoft, Suffolk.
Any of you guys know wher I can lay my grubby little mits on a tin of green paint that they painted the early blocks with? (as in the pic) Am greatfull for all help.
Shane
shane
Member #: 1246
Lowestoft, Suffolk.
What pic?
I got a tin of BMC green engine paint from Moss a while ago if that helps.
shane
Member #: 1246
Lowestoft, Suffolk.
I cant get the dam thing to up load, seems anything i transfere from my phone or pics I have been sent will by nothing in my photos file will!??
Thanks for that Rob, how large is the tin, and how much was it?
Thanks
Shane.
I was after BMC green, ended up with Kawasaki green. Lol
The thing is, you cant see what colour the block is because there's so much other shite in the way. :)
Edited by matty on 7th Jan, 2007.
themaninthesuitcase
Member #: 1124
Surrey
Frost do a MOWOG green by POR15, £18 for 473ml.
shane
Member #: 1246
Lowestoft, Suffolk.
Thanks for that, will have a ring around tomorrow.
Shane.
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
shaney ... where did you get kawasaki green engine paint from? Thats the colour my mini is due to be sprayed and i'd love a matching block! :)
shane
Member #: 1246
Lowestoft, Suffolk.
Matty was they man wit kawazaki green, I was after bmc green.
Shane.
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
my bad *blush*
matty, i forward that question to you
shane
Member #: 1246
Lowestoft, Suffolk.
Ordered a tin from somerford mini yesterday, they said it came in two shades, the chap on the phone tried explaing the two shades, lol. Will add to post when it arrives.
Shane.
The green is a standard gloss paint from homebase! Benross swares by it, *wink* so Ive gone with it and I got the colour mixed up.
I cant remember the exact name...I'll have a look later and let you know!
Ric
Member #: 36
Basingstoke
gloss?! Will that not get really soft when it gets hot?
Apparently not!!
I get the paint from Moss. EP3 is the more paler green, EP3A is the nice strong green that every fast engine should be.
They sell it in tins or rattle-can. The rattle cans cover very well, and will do two full engines and transmissions.
It's only as good as what's on the underside though, so de-rust and de-grime the compnents you want the paint to actually stick to, apply a thin 'dusting' and leave to dry for a few hours, then set to it.
Job's a goodun.
ps - don't forget all the best engines are green....
shane
Member #: 1246
Lowestoft, Suffolk.
Yes Ric gloss,its great!!! I've used red Crown on several engines and found it to be better than a few "engine laquer".
The tin arrived today, nice green, and a reasonably priced £12.49 to my doorstep!!
Shane.
wethepeople
Member #: 176
Pre-op Transvestite
Felixstowe, Suffolk
how many banana's do you get for using green paint on your block dave?
gotta be worth more than those "performance chips" i keep seeing on ebay for 2.99!
andeh
Member #: 97
Near Daventry, midlands
the por15 paint is good i've tried it, the stuff from moss is shite (tins), i've tried it.
best by far is homebase radiator paint (1), get it mixed up in any colour and it doesnt chip. infact its so good im gonne go get some at the weekend.
the por15 (2) comes a close second
common 2pack (3) in a rattle can come way over anything else with engine paint/enamel written on the tin as they are all shite, take a lot of covering and chip very easily...
This is what i've found from using all of the above paints and more.
i cant echo what dave said enough, if you dont de-grease and de-rust you may aswell not bother.
Edited by andeh on 11th Jan, 2007.
The first thing I changed.
Before:
You may just see the colour on the head there...
After:
MM Yummy!
Minispares sells those cans as well.
Its a direct ratio for green paint and power;
Green paint (10ml) = power (1bhp)
*laughing*
mickeyturbo
Member #: 1212
braintree, essex
i have some early 850 green paint i dont need anymore, pm me if interested.
shane
Member #: 1246
Lowestoft, Suffolk.
if thats the case im gonna use the whole tin for an extra 50 hp!!!
Bring on the paint brush!!!
Shane.
*laughing*
hario
Member #: 2885
Radiator paint?? ..Really?
I got my green engine paint off ebay
