Home > General Chat > A milestone reached!
shane
Member #: 1246
Lowestoft, Suffolk.
The missus has been at work all weekend so has left me with the whole weekend free, so I've locked myself in the workshop and been beavering away all weekend!!
I now have finished building my front subby (less brake line, and possible CV gaitor swap). I have also stripped all the rear suspension down inpected, cleaned, and given 2 coats of paint. When dry all should be ready to assemble, just need to get my beam axle on order in the mornin. After this, its on with the engine!!!
Monster22
Member #: 39
Looking good, I'm a few days behind you...! Stripped subframes and dirty bits ready to clean then fit new bushes etc
M
Ooh shiny shiny!!
shane
Member #: 1246
Lowestoft, Suffolk.
I swear I was a magpie in a former life!!!!! I cant help but give bits a polish or paint!! This is the second mini I have built from scratch, the first was intentionly for concours / show use, and this one was meant to be built on a strict budget but is going along the same lines as the first. NOT A GOOD SIGN!
Shane,
shane
Member #: 1246
Lowestoft, Suffolk.
Been back at again tonight, beam axle arrived today (damaged, but thats another storie, bloody hudersfileld...) managed to get radius arms back together, with brakes, just need to fit the split pins for the bearings and slip the drums on, PROGRESS AT LAST!!
Now for the engine!!
Shane.
Scruffy
Member #: 328
Seaford Rise, South Australia
Shane.
You need to make some brackets to support the other end of the stub axle. Std diameter pins will not last long with coil overs - I speak from experience when I had a pin let go (shear) on the M25 a number of years ago and had to get recovered. KAD arms use a thicker diameter to compensate when you use coil overs.
On 5th Sep, 2011 Vegard said:
Turbo Shed
Member #: 30
Epsom, Surrey
Looks good and so does that work shop.
Monster22
Member #: 39
Good tip Scruffy.
shane
Member #: 1246
Lowestoft, Suffolk.
Turbo shed, its my works workshop, we've got loads of space, heating and tea making facilites (and no nagging missus!!), what more could you want, its the tits!!!
Scruffy, can the pins be replaced, do you have any pics of your supports? (if you dont mind shareing?)
thanks
Shane.
