| Home > Help Needed / General Tech Chat > Is it just running rich? | |||||||
126 Posts Member #: 244 Advanced Member |
8th May, 2004 at 08:08:36pm
Hi all, I am new to your forums but have had plenty of help from previous topics! I recently purchased a complete almost finished project Mini Turbo. I stripped the car of everything mechanical and fitted it to my own project which is a speedster mini (no roof, no convertible, DRY WEATHER ONLY!) I have just today got everything plumbed in and running. The problem that I am having is that even though the car ticks over fine (but does not need choke to start, even after standing for a week!) if i rev it a little a few times I find myself choking on white/light gray smoke. It does smell like very rich burnt fuel. The oil pressure is great and settles at 10 ft lb when the engine is warm(ish) but revving to say 3k sees the needle shoot up on the pressure gauge. It does not appear to be using any water, there is definitely no water in the oil (just a little moisture on the inside of the filler cap from not being used for months and months). The engine, as far as I am aware, is a bog standard MG turbo. Does anyone have any ideas what is causing the smoke (being in a garage doesn't help!) or have you experienced the same thing on your car and fixed it? Hope you can help. Many thanks Dave. Speedster turbo under construction |
9th May, 2004 at 07:28:50am
Hi dave, welcome in turbo minis madness
9th May, 2004 at 08:21:37am
Thanks Fab, The smoke isn't blue, it is a white/gray kinda colour the smell is not that of burning oil. I will try the mixture today.
![]() 341 Posts Member #: 259 Member grays, essex |
9th May, 2004 at 08:52:50am
try taking the head off and de-coking it, you may find theres a build up of crap in the cylinders, if not try all your turbo oil seals, my mate had that problem with his one once. it may b small but it purfectly formed
9th May, 2004 at 09:10:00am
something wrong
9th May, 2004 at 05:42:19pm
I have tweeked the mixture, it seems better. I couldn't get it to put out the amount of smoke it was yesterday.
9th May, 2004 at 06:05:23pm
If it is running too rich the plugs and exhaust would be sooted up. On 21st Jan, 2011 fastcarl said:
