| Home > Help Needed / General Tech Chat > Fabricage | |||||||
13th Jan, 2007 at 05:34:55pm
Hello just wondering if anyone has used a cage from these guys and what the quality is like, they say the cages are not technically msa certified but what is involved in getting a certificate? cheers |
397 Posts Member #: 694 Senior Member Shropshire |
13th Jan, 2007 at 05:40:01pm
On 13th of Jan, 2007 at 05:34pm gav said:
They say the cages are not technically msa certified but what is involved in getting a certificate? cheers Erm not sure about that as i spoke to peter last week about a cage he has even sent me a copy of the drawings he sent to the MSA in oder to get a certificate for the cage. Also i think but i could be wrong that quite a lot of the mini 7 racers use his kit so they must have a certificate. Obviously it depends on the cage you seleced though. |
13th Jan, 2007 at 05:42:12pm
Ah its probabably to keep the cost down, thats good to know though cheers. With these cages do you have to box them in at the feet or are they made to weld straight to the floor? |
13th Jan, 2007 at 05:43:17pm
Could not answer that. However Jimster/Endaf use peter's cages so i will leave that one up them :) |
14th Jan, 2007 at 06:18:08pm
I think i remember jim saying he boxed them in so he could weld the cage to the roof first, but i dont see how they couldn't make a weld in cage the same dimensions as a bolt in. Oh and jim how the hell you painted your cage is beyond me lol. |
16th Jan, 2007 at 04:26:17pm
On 14th of Jan, 2007 at 06:18pm gav said:
I think i remember jim saying he boxed them in so he could weld the cage to the roof first, but i dont see how they couldn't make a weld in cage the same dimensions as a bolt in. Oh and jim how the hell you painted your cage is beyond me lol. These weld in cages are design to sit on boxes which are welded in - so the cage is tacked into place whilst resting on the boxes. The boxes are removed allowing the cage to drop by 4 inches so the bars can be seam welded at the top. The cage is then raised back up put onto the boxes and welded into the car/floor On 5th Sep, 2011 Vegard said:
16th Jan, 2007 at 04:59:39pm
Not sure how Jim painted his cage but in the past I have painted the cage first (masking the weld joints), fitted in the car, welded up, masked around the joints adn sprayed the joints up, anywhere you can't get a gun you won't be able to see so a brush finish is fine. Every day is a school day ...........
16th Jan, 2007 at 10:46:56pm
As has been said I used a fabricage kit for the base for my cage, (Although only the main hoop, front legs and the bit which goes over the windscreen) the rest endaf made. http://www.owensfabrication.com
Edited by Jimster on 16th Jan, 2007. Team www.sheepspeed.com Racing
