| Home > Technical Chat > New MegaJolt Lite Jr. Firmware- V3.1.0 | |||||||
5 Posts Member #: 1447 Junior Member |
13th Jan, 2007 at 09:33:55pm
For those of you running Megajolt Igniton, I have some good news for you- an update to the MJLJ firmware and matching PC configuration software!
Edited by brentpicasso on 13th Jan, 2007. Brent Picasso
13th Jan, 2007 at 09:39:49pm
hi and thanks. welcome to the site. no longer a series, but still 1.3 turbo.
13th Jan, 2007 at 09:49:40pm
Welcome Brent & thanks for all the work you've done on MJ.
14th Jan, 2007 at 04:04:10am
hi brent welcome ,you tracked us down !!! lol Edited by robert on 14th Jan, 2007. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
14th Jan, 2007 at 10:55:00am
Hi Brent.
AlexF |
15th Jan, 2007 at 08:42:32am
Wow, I feel like I'm home! :) Thanks for your support and enthusiasm.
Edited by brentpicasso on 15th Jan, 2007. Brent Picasso
15th Jan, 2007 at 09:22:41am
hi Brent, first of all, much respect due for your work.
15th Jan, 2007 at 11:42:09am
I have 30 odd MAP sensors in stock!
AlexF |
15th Jan, 2007 at 12:03:38pm
i thought the 3bar ones are easy enough to come by?
15th Jan, 2007 at 12:17:44pm
What boost are you running with the mj iain? |
15th Jan, 2007 at 12:27:42pm
On 15th of Jan, 2007 at 08:42am brentpicasso said:
A TPS configured MJLJ can also be used with an external MAP sensor... Do you mean it can be used with an external MAP sensor instead of or at the same time as (for correction) as a TPS? Every day is a school day ...........
15th Jan, 2007 at 12:46:35pm
i have emerald |
15th Jan, 2007 at 01:25:39pm
3 or even 5 bar sensors themselves isn't a problem.
AlexF |
16th Jan, 2007 at 05:22:20pm
A TPS configured MJLJ can also be used with an external MAP sensor... Do you mean it can be used with an external MAP sensor instead of or at the same time as (for correction) as a TPS? It would use a MAP sensor in lieu of the TPS. Once appropriately calibrated, it would be no different than the internal MAP sensor, aside from the extended range. T2Cubby, I've never seen that problem before! Are you sending new values to the controller, *then* commiting the changes to flash? Brent Brent Picasso
16th Jan, 2007 at 07:46:41pm
Yes Brent I was doing exactly that, but I didnt have a huge amount of time to mess about with it as Im working away at the moment, when I get back I'm going to spend more time on it and try to find what the problem is. |
