| Home > General Chat > Sleeving pushrods | |||||||
17th Jan, 2007 at 05:51:07pm
what do people use to sleeve the pushrods?
17th Jan, 2007 at 05:55:48pm
a tube, |
17th Jan, 2007 at 06:03:12pm
any material in particular? "Turbo's make torque, and torque makes fun"
17th Jan, 2007 at 06:23:45pm
TITANIUM!!!!!!
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
17th Jan, 2007 at 06:24:36pm
one head that passed through my hands was done with mild steel tube I've seen the future and tbh its Pie
17th Jan, 2007 at 06:25:17pm
OH! have you broken through joe ?
17th Jan, 2007 at 06:48:43pm
I assume the reason for sleeving is to reduce flex in the rod?
17th Jan, 2007 at 06:52:44pm
not me steve, just got this:
17th Jan, 2007 at 07:01:15pm
On 17th of Jan, 2007 at 06:48pm matty said:
I assume the reason for sleeving is to reduce flex in the rod? How do get the sleeve on if its an interference fit, as there is a cup one end and a ball on the other? i believe he means sleevign the hole tha tthe pushrod passes through in the head, as enthusiastic porting has broken into it from the port. turbo 16v k-series 11.9@118.9 :)
17th Jan, 2007 at 07:07:51pm
Ah I get ya! :$
17th Jan, 2007 at 10:56:23pm
Mine were abit small on the i/d of the sleeve.So had to grind the ball end of the pushrod down a bit to get them through the head........
Edited by Dangerous on 17th Jan, 2007.
17th Jan, 2007 at 11:17:24pm
i saw that thread when i did a search, what material were the sleeves in yours? "Turbo's make torque, and torque makes fun"
17th Jan, 2007 at 11:18:51pm
mild steel,the top is counterbored/chamfered to aid the oil going back down too
17th Jan, 2007 at 11:38:57pm
the sleve needs to be reasonably thin walled
Edited by BENROSS on 17th Jan, 2007.
18th Jan, 2007 at 08:17:51am
when my big 1380 head was done we broke thorugh in the inlet, but we got some copper pipe then silver soldered it in then drilled it out , that worked a treat always looking for them bigger bunches of bannanas |
18th Jan, 2007 at 04:51:42pm
I don't understand why engine builders advertise with slleved pushrod holes. THEY ARE ALL SLEEVED FROM THE FACTORY on 940 heads.
18th Jan, 2007 at 05:31:12pm
still, better than a hole in the port... "Turbo's make torque, and torque makes fun"
19th Jan, 2007 at 08:25:44am
19th Jan, 2007 at 12:42:38pm
i see what youre getting at vegard, some tuners advertise it as a performance mod when basically it is just a repair.
19th Jan, 2007 at 12:50:25pm
I think vegards getting at the facyt the940 casting doesn't really need to be taken out that far between the push rods, the 295 with its smallr valves even less so IIRC.
20th Jan, 2007 at 05:07:15pm
On 19th of Jan, 2007 at 12:42pm joeybaby83 said:
i see what youre getting at vegard, some tuners advertise it as a performance mod when basically it is just a repair. but is it really this big a deal? No, it's not a repair nor a mod. It's there from the factory for God's sake. If anyone grind through the ORIGINAL FACTORY FITTED sleeve, they haven't got a clue. Have you guys seen a 940 head without this sleeve? On 13th Jul, 2012 Ben H said:
20th Jan, 2007 at 05:15:00pm
Vegard,
20th Jan, 2007 at 06:20:27pm
On 18th of Jan, 2007 at 04:51pm Vegard said:
I don't understand why engine builders advertise with slleved pushrod holes. THEY ARE ALL SLEEVED FROM THE FACTORY on 940 heads. If you break through the factory sleeve while porting, you're doing something wrong. no they are not,!! there is however a counterbore top and bottom which you may be getting confused with,as it does look like a sleeve, carl |
20th Jan, 2007 at 06:56:45pm
Are you for real? I pressed one out once, but I have never tried later on because I have never needed. to. I stand corrected in that case. but there's still no need for sleeves :) On 13th Jul, 2012 Ben H said:
20th Jan, 2007 at 08:20:15pm
All the 7 940 heads I have in my garage are counterbored as Carl said above.
