Home > Show Us Yours! > Can you see what is is yet?
Bodge Job
Member #: 953
London
something to do with the brake's maybe ????????
TURBO ME
Member #: 772
new york
fuel rail
giallofly
Member #: 164
The Stig..
Newport Pagnell
yep, fuel rail....
danboy
Member #: 1381
Haven't a clue really but it looks like some sort of fuel switching/ mixing device.
Regards
Dave
Definatley a Fuel Rail! Those in the middle are injectors!
Edited by MikeRace on 21st Jan, 2007.
AL
Member #: 1347
Croydon (South London)
But whats the bottom bar for? Mxing something else with the fuel? possibly to make a larger explosion??? *wink*
danboy
Member #: 1381
If they are injectors I can see no point squirting them into a small diameter tube. They may be just solenoid controlled on/off valves, this would make more sense.
Wonder how long we will have to wait to find out?
Still it's better at the pc than freezing your nuts off in the garage
Regards
Dave
Injector flow test rig?
A clue:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=9224
As I now have everything to trial the siamesed port code, but no code as yet, I thought I would pick this idea up again.
It is a couple of pieces of fuel rail with injectors and a regulator. Cost me pennies to make because the rail came with some MPi injectors from a Rover 620 Turbo.
If it works - great, you will all be using one next year. If it doesn't, at least I've learnt how to set up the Megasquirt.
part of a metered fuel supply for an su?
Unless you were to run the float bowl nearly dry, I cant see how having a metered supply feeding the float bowl, could possibly be of any benefit.
the float bowl is basically a stagnant supply of fuel for the jet to draw from.Raising or lowering the level of fuel in there, shouldnt affect the amount of fuel delivered, until of course, the fuel level is too low.
Why not just suppplement the SU, by firing an injector at its mouth ? Or does that also cause complications ?
The mixture is extremely sensitive to the level in the float bowl. I've got my wideband fitted and working. A half turn of the mixture screw will alter the mixture by about 1 point. That alters the distance between the top of the jet and the level in the bowl by less than a millimetre.
The flow through the jet is dependant of the differential pressure between the pressure in the float bowl and the depression caused by the velocity of the air over the bridge. The lower the float bowl level, the lower the flow of fuel.
If you supply the carb with the amount of fuel it needs to achieve a specific air/fuel ratio, the float bowl level will reach a point of equilibrium so that what goes in, goes out through the jet.
The only problem, as I see it, is what happens during transient conditions. Will the system react quick enough for a rapid opening of the throttle? The piston in the carb is damped by the plunger and spring to create the affect of acceleration enrichment. This will still work but the level in the float bowl will drop until the flow goes up to match.
is it some kind of drug parafanalia?
evolotion
Member #: 83
Glasgow, Scotland
I have no idea whether itll work or not so wont comment on that, all i will say is prop's for giving it a shot! If all it costs you is your time then its rude not too :)
Denis O'Brien.
evolotion
Member #: 83
Glasgow, Scotland
p.s. could you do me a favour, if theres any part number son that regulator, could you tell me them please. want to see if its the same as my regulator
Denis O'Brien.
Thats because dropping the jet, places it at a different section of the needle. Not becuase if the height of fuel in the bowl.
Dont forget, thats how an SU works. Fuel is metered by the jet/needle orifice size.
Fuel level in float bowl has negligable effect.
Think about a painters airbrush kit...Does paint flow reduce, as the level of paint drops in its reservoir ? It would make for very tricky work if it did.
Unless you can increas or decrease AIR pressure within the float bowl, the pressure differential between jet, and bowl wil remain the same, regardless of float bowl level. As I said, the fuel in the float bowl is essentially stagnant.
When on boost, turn your fuel pump off, and see if the car runs any different...until of course the bowl is empty.
I know mine didnt.
The fuel inside the bowl is NOT under any pressure, other than that of the boosted air around it. If there was any actual pressure, fuel would be blown straight out the jet. Once the bowl is full, needle valve closes, thats it, stagnant fuel reserve.
We both obviously have very different understandings of how the carburettor works.
Try the bit I highlighted in bold. I know I did many times, when fault finding other problems with my fuel supply.
If AFR's change the instant you turn the pump off, then maybe you have a chance of it succeeding. I honestly dont see how they would though.
Good luck with it *wink*
Edited by stevieturbo on 21st Jan, 2007.
Evo - no part number I'm afaid, although it looks exactly the same as the MPi one I have.
I think it would be safe to assume that all Rover pressure regulators from mid to late 90s are the same, they all control to 3 bar.
Stevie, food for thought there.
I've revisited some of my calcs and I think that I have over estimated the effect of the float chamber level.
The SU Tuning book states that 1 once per sq in is the pressure required to lift the fuel 1/8" to 1/4" up the nozzle. If you calculate it, 1 oz/in2 can lift over two inches. So you are right, minimal effect on AFR from float bowl level.
However, if I seal the float bowl (N/A), adjust the nozzle to the top of the bridge and use a needle that would otherwise give a lean setting, then the system will force more fuel through the carburetor giving the AFR we want.
Im ot really sure what you are trying to desribe there...
Maybe its something like this ??
Do you know what the rubber pipe linking the float bowl air, to a drilling in the carb at the plenum does ??
On boost, nothing.
During vacuum, ie low throttle openings....
A calibrated drilling at the plenum face, effectively creates a restriction here, to vacuum in the intake manifold.
This reduces the air pressure in the float bowl, which in turn helps for a low rpm/cruise lean mixture.
Lots of carbs have similar vac-weakening devices. I think the turbo SU is the only one to have it though ??
I'm actually developing this on a N/A engine that I've built just for the EFI development, but due to the lack of code will try this first.
Hence all the above is about N/A at the moment. One thing at a time.
Edited by Paul S on 22nd Jan, 2007.
