| Home > Technical Chat > ARP. i am impressed. | |||||||
28th Jan, 2007 at 06:15:03pm
seing as gen rover big end bolts are now quite expensive and the ARP work out cheaper i aquired some,
28th Jan, 2007 at 07:13:36pm
A converted man i see....
Edited by Doodmeister on 28th Jan, 2007. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
28th Jan, 2007 at 09:11:25pm
Here's a question for yas.
28th Jan, 2007 at 09:28:10pm
i supose you could have cut any excess exposed threaded section off, iv'e heard of this before ,the fouling that is!
28th Jan, 2007 at 11:11:47pm
Just out of interest Carl, what sort of revs did you used to subject standard rover rod bolts/nuts to as i believe these are what i have? -MINI CLUBMAN 1380 TURBO- |
29th Jan, 2007 at 01:10:36am
On 28th of Jan, 2007 at 09:28pm fastcarl said:
i supose you could have cut any excess exposed threaded section off, iv'e heard of this before ,the fouling that is! carl The depth of the nuts themselves would still have been too much. And from what I recall, I couldnt have removed any material from the box either.... As for std rod bolts.... I did rev mine breifly to 8000+ several times when I made a poor cam selection. With a sensible turbo use cam, I regularly seen 7000+ and never experienced problems. 9.85 @ 145mph
29th Jan, 2007 at 08:43:13am
I think carl has just proven to us, if he has been using std rod bolts in his engine then this statement may be true:
29th Jan, 2007 at 10:26:06am
I seriously doubt it! |
29th Jan, 2007 at 11:24:56am
On 29th of Jan, 2007 at 10:26am paul wiginton said:
When fitted, the flywheel end fouled the gearbox, and the gearbox wouldnt bolt up. Gavin Wakely came across this problem about 8+ years ago. He built up the gearbox casing with weld then relieved the inside to clear the ARPs. Paul Much simpler than removing a few mm of the bolts for sure
29th Jan, 2007 at 05:31:52pm
i supose you could have cut any excess exposed threaded section off, iv'e heard of this before ,the fouling that is! carl The depth of the nuts themselves would still have been too much. And from what I recall, I couldnt have removed any material from the box either.... read the post before answering Veg
29th Jan, 2007 at 07:13:58pm
the ARP mains stud setup is something iv'e not dealt with, so i can assume these use high head nuts ,
30th Jan, 2007 at 02:39:37pm
Really is amazing how good the standard rod bolts are!!! Think i will be moving to ARP on the next strip down though, a cheaper and even better product. -MINI CLUBMAN 1380 TURBO- |
30th Jan, 2007 at 06:45:06pm
I'll measure the nuts later. They are the typical taller nut as used with ARP style fasteners. 9.85 @ 145mph
30th Jan, 2007 at 07:04:51pm
Ive always used ARP. I wouldnt dare use anything else.
