| Home > Help Needed / General Tech Chat > Valve seat question | |||||||
28th Jan, 2007 at 06:58:13pm
Had new valve seats cut, and when i have started to lap the valves into the head, it appears the inlets seem to have a very thin seat in comparison to the exhaust.
Edited by joeybaby83 on 28th Jan, 2007. "Turbo's make torque, and torque makes fun"
28th Jan, 2007 at 07:09:32pm
If it's for Turbo use leave it well alone as the valve uses the seat to remove heat from the head of the valve. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
28th Jan, 2007 at 09:12:29pm
Ditto above. A wide valve seat esp on the exhaust wont do any harm. 9.85 @ 145mph
28th Jan, 2007 at 10:01:31pm
Righto, thanks lads "Turbo's make torque, and torque makes fun"
2nd Aug, 2007 at 09:33:25am
Just had a look at this. The guy who has ground your seat is obviously a wanker. Look at where the seat of the valve is. It's on the inner side of the existing seat. So where can you grind?
2nd Aug, 2007 at 11:02:54am
go up a valve size on the inlets to 35.6mm and de shroude around the combustion chamber so the valve flows well
2nd Aug, 2007 at 12:12:55pm
If using a proper cutter, this will sort out the shrouding as well.
2nd Aug, 2007 at 05:02:10pm
Was`about to say that 3 angle seats would probably sort it out.
2nd Aug, 2007 at 05:25:32pm
no, 30.93mm inlets, its a 295 head, not after mad power and concious of it cracking so sticking with smallish valves.
2nd Aug, 2007 at 05:47:58pm
yes of course pm sent
2nd Aug, 2007 at 09:04:18pm
Even so, fit bigger inlet valves. That is no good even if used with a 3 angle cutter. That will just ruin the next up size valve seat. On 13th Jul, 2012 Ben H said:
2nd Aug, 2007 at 10:07:33pm
fishtits, just bought those inlets :( "Turbo's make torque, and torque makes fun"
2nd Aug, 2007 at 10:19:44pm
veg, fitting larger inlet valves and then de shrouding around the valve to bring the flow Potential up
Edited by BENROSS on 2nd Aug, 2007.
3rd Aug, 2007 at 07:35:44am
On 2nd of Aug, 2007 at 10:19pm BENROSS said:
also opening the valve throat to suite the larger valve, these two mods togeather flashing the head will make a stormer of a head The proper cutter will do this. The one I pictures would make a nice perfect radius there. Look at the pictures of the finished seats I posted. Yummy! Nice venturi effect as well. On 13th Jul, 2012 Ben H said:
3rd Aug, 2007 at 10:27:37am
yes i agree V if the seat was cut like yours to start with but..... the valve seat has been taken too wide and the valve now sits on the btm of the seat
3rd Aug, 2007 at 12:01:28pm
Exactly, so a bigger valve and a proper cut seat would make that head beatiful. There's sufficient meat there to do it. Buy 32mm inlets from Paul Ivey. On 13th Jul, 2012 Ben H said:
4th Aug, 2007 at 05:39:48pm
will keep you posted V
4th Aug, 2007 at 07:29:28pm
had a closer look today and i think you guys are right... :(
5th Aug, 2007 at 10:01:43am
whack it in the post jo with all the bits for the head buddy
15th Sep, 2007 at 12:09:51am
Only just got round to taking a few snaps of Steve's (aka Benross's) handywork rescuing my head:
15th Sep, 2007 at 11:01:55am
Now let's see those valve seats then! :) Don't like the look of that massive inlet. Too big a valve will be an obstruction there on a small bore as the inlet port and throat cannot flow sufficient air for that valve. How big is it?
15th Sep, 2007 at 11:59:45am
33mm i believe, im sure it will do just as I want it too!
15th Sep, 2007 at 03:11:26pm
V thes valves are the correct ratio 18% differential and de shrouded around the valveto make them flow
15th Sep, 2007 at 09:42:23pm
I thought it looked like a AEG163 35,6mm inlet. That's too big for a 295head. If they are 33,3/29,4 valves they might work, although the valves are a bit bigger then necessary. They are however easy and cheap to get hold of.
16th Sep, 2007 at 11:10:06am
i had to strike a ballance with de shrouding the valves and getting the correct CR in there for joey
