| Home > Help Needed / General Tech Chat > Cooper S Hardy Spicer or not?? | |||||||
29th Jan, 2007 at 06:02:25pm
Does any one have a pot joint to hand that they can measure, with some calipers, the shaft end, the bit that fits into the box???....
29th Jan, 2007 at 06:15:16pm
Pot joints are 1.250" or 31.75mm where they fit in the seal. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
29th Jan, 2007 at 06:47:09pm
i was always told the hardy spicers were bigger for sure, hence them being stronger. |
29th Jan, 2007 at 06:53:27pm
On 29th of Jan, 2007 at 06:15pm Axel said:
Pot joints are 1.250" or 31.75mm where they fit in the seal. Yeh? cos thats the diameter of these HS flanges i have. Odd!! Im thinking the auto has something to do wih this
29th Jan, 2007 at 07:08:07pm
I think there was some smaller diameter ones made for the auto box yes. I have the proper ones here, you will get proper ones if you buy for a LSD
Edited by miniminor63 on 29th Jan, 2007. |
29th Jan, 2007 at 07:15:58pm
the S type ar bigger on dia, you need a different side cover. Edited by fastcarl on 29th Jan, 2007. |
29th Jan, 2007 at 07:23:33pm
Just been to measure mine and it's 1.375" as opposed to the 1.250 auto.
30th Jan, 2007 at 08:35:04am
S and Auto are the same. The Auto went Pot in 73 didn't it?
30th Jan, 2007 at 08:38:51am
there are some strange hardy outputs around, its been up on the yank board too Vegard. |
30th Jan, 2007 at 09:35:28am
Just measured my spare pair and they too are 1.375, I do know these came from an auto box so Vegard you are totally correct.
