Home > General Chat > inertia switch!
t3gav
Member #: 229
Gavin@minispares.com
kent
hi guys, i know there are already a few posts about how to wire in fuel pumps etc but i cant find anywhere who sells the relay, i spoke to avonbar who said it is a major re wire job and not to bother seems a bit dangerous to me as everyone says its easy. Also is wiring an inertia swith that easy or are there any tips you'd advise? cheers gav
http://www.turbominis.co.uk/index.php?p=vt&tid=299
http://www.turbominis.co.uk/index.php?p=vt&tid=297
T3Tone
Member #: 252
Sunny suffolk
I have just wired in a 25amp switch to supply feed to pump, no probs as yet!!!!! *indifferent* ( But 4 safety surely the pump needs to have a cut off if involved in an accident??????? ) DOH!
Edited by T3Tone on 12th May, 2004.
-MINI CLUBMAN 1380 TURBO-
I had the same problem finding the relay.
you want www.maplin.co.uk
Part number LJ91Y
None in stock at the moment though
Wil
