Home > General Chat > Broke down twice on the way home, then the lights went out
All down to those shit fuse boxes.
It's been such a long time since I've had to open a bonnet at the side of the road, I forgot how embarrassing it can be.
Richie
Member #: 628
Will....... with the cold weather i would perhaps consider moving the fuse box into the car *wink* worked wonders for me in the past.
Edited by Richie on 6th Feb, 2007.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
I think you are probably right. But I think new crimps and a new box should last another 15 years!!
JT
Member #: 637
Hertfordshire
wd 40! and a double check that that everything is crimped well and not come loose!
thats what i do, used to get props when i first bought the car then i put new connectors on them and changed the fuse box! no props so far, touch wood
how hard is it to put the box into the car then?
does it mean re-wiring everything or just feeding it all through?
cheers
josh
My build thread..
Richie
Member #: 628
i fed it all through so it went under the dash facing the floor if you know what i mean, dead easy just takes a lil bit time, you can also convert the fuse box type to blade fuses rather than the bullit type which i prefer *wink* last much longer too
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
JT
Member #: 637
Hertfordshire
o yer all the fuses were rusty aswell lol
bit of sandpaper snd jobs a gooden lol!
My build thread..
have you bought a renault?
JT
Member #: 637
Hertfordshire
who me?
no, why??
My build thread..
jimmy
Member #: 829
essex
I put my fuse box inside the car when i fitted my turbo box
1293 Turbo mini
jamesfawcett
Member #: 218
Bingley, West Yorkshire
ive switched mine with a blade one its one of the first things i always do when i get a new mini
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I need a new loom really but the thought of working on that depresses me.
On 7th Nov, 2008 Nic said:
naeJ
m
mattyking
Member #: 873
Thatcham, berkshire
yea i agree, pissed about with the normal fuse box every so often when eletrics went so i replaced whole lot with new fuse box and connectors to a blade type now and its fine works a treat. they cheap get hold of too. demon tweeks sell em. only took about half hour change over and mount new fuse box.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have put a blade one in too, fixed all the problems. You can only clean the connections so many times.
The real problem with the normal fuse box is that the blades are conected to the fuse hulser by a rivet. Once the connection between blade and fuse holder corrode no amount of cleaning or wd40 solves the problem.
http://www.twin-turbo.co.uk
Richie
Member #: 628
job done then mate *wink* did you bring em into the car too or have you just exchanged the box in situ ?
Richie
EDIT: a canny tip i could give is to get a small container with foam in and fill it with 2 spare fuses (per amp that the car uses) and strap the box under your seat or stow it away somewhere safe in the car.......on a rainy day if you get a problem with a fuse pull over and change it inside the car dont get wet that way *wink*
Edited by Richie on 7th Feb, 2007.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
