| Home > Help Needed / General Tech Chat > suspension cones | |||||||
11th Feb, 2007 at 06:18:41pm
hello any of you clever people ever managed to fit a set of cones without removing the top arms? |
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
11th Feb, 2007 at 06:34:33pm
Do you mean remove the std ally trumpet to fit hi lo's? if so it is possible, compress the donut as much as possible, the trumpet will not come out due to space restrictions, but if you cut it half with a hacksaw blade it can then be removed, this is a very time consuming and yehaaaa way of doing it tho, much easier and quicker to remove top arm IMHO, I only did it this way as I was unable to undo the shaft bolt at the rear of the subby. To fit the hi lo, I wound it down as low as poss then it slipped in was a little tight, these was an old minisport set, but be warned some of the cheaper sets may be a little taller and not allow this.
11th Feb, 2007 at 06:39:35pm
no replacing the trumpet is easy i mean replacing the cones, cheers |
11th Feb, 2007 at 09:09:23pm
LOL sorry, from memory I believe the they wont fit thru between the top arm and the subby.
11th Feb, 2007 at 09:13:05pm
I've always had to get the top arms off.
11th Feb, 2007 at 09:23:16pm
as long as you or previous owners have kept it all greased up then it should be ok!
My build thread..
14th Feb, 2007 at 02:12:33am
gav! im after another set of old knackered suspension cones can i have yours? obviously id pay if you want some money for them! the older the better! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
14th Feb, 2007 at 08:08:17pm
On 11th of Feb, 2007 at 09:13pm RogerM said:
I've always had to get the top arms off. It's not as bad a job as others will have you believe. Is it possible to remove them with the engine in place? I've only changed the cones when I've had the engine out, however I'm not sure if there's space to get to the bolts, and remove them, with the engine in place. Isambard Kingdom Brunel said:
14th Feb, 2007 at 09:11:49pm
So long as you take of both of the big nuts (rear ones a pain but possible) and then remove the mounting plate it'll be fine with just the rad out of the way. Every day is a school day ...........
15th Feb, 2007 at 12:57:42pm
I find the back nut the easiest to undo its the one near the rad thats a pain, feebs i'm not sure if you'll want the cones the car is stupidly low so i think they've passed it but your more than welcome to them foc. |
15th Feb, 2007 at 06:39:40pm
Rad has to come out (unless your tripple jointed and have the hands of an embrio) but not the engine Every day is a school day ...........
