Home > Help Needed / General Tech Chat > OT: Machine Tool On/Off Switch
Badger
Member #: 1488
Bit OT but I am currently trying to get my lathe operational (it's an old Globe with 3.5" throw or so) but to do so I need to completely rewire it. I've been looking for a latching on/off switch for it for ages but can't seem to find one, and was wondering if any of you guys had an idea? I live in Bristol btw.
Last time I used it I turned up an ally button for my mates handbrake- with the only on/off switch being the plug on the wall behind the lathe 'twas a bit hairy for my liking!
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
you want a proper breaker type switch.
a bit like this:
http://members.optushome.com.au/terrybrown.../LatheP1696.jpg
I'm just looking in RS now...
http://rswww.com/cgi-bin/bv/rswww/searchBr...=ukie&Nr=avl:uk
Badger
Member #: 1488
Hmmmm... not exactly what I'm after! I don't want to have to fit a relay or anything. Just need a simple on/off switch like you see on most lathes sold by machine mart etc. Only place I can get one I found is machine mart spares! And they charge over the odds...
have a look on the online RS catalouge
you will get anything there
Badger
Member #: 1488
Have just spent the last hour or so looking at it... can't seem to find exactly what I want and since my knowledge of such items is minimal it's a wee bit difficult!
how exactly are you going to find something if you dont know what it is you need??.
carl
Badger
Member #: 1488
carl
Bloody good question! I know what I want, I just don't know the technical description. As far as I can understand it's a spdt start/stop push button switch. I've got it pictured in me head, we used to use them all the time in the workshops.
Heres a pic... On/off switch on this.
http://www.machinemart.co.uk/images/librar...e/060712510.jpg
There's an RS in St Philips, might be worth calling in and talking to them if you're not entirely sure what you're after.
By the way the item you're after is called a starter.
If ebay is your thing this link might help:
http://business.search.ebay.co.uk/starter_...gZ1QQsofocusZbs
as rob says
this is EXACTLEY what you want *wink*
this item is perfect for you application bolted may be directley to the lathe or wall mounted
So please order with confidence *wink*
http://cgi.ebay.co.uk/3HP-240-VOLTS-DOL-MO...1QQcmdZViewItem
Edited by BENROSS on 15th Feb, 2007.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Are you looking for something like this?
http://cgi.ebay.co.uk/3HP-240-VOLTS-DOL-MO...oQQcmdZViewItem
The thing is it will have to have some sort of relay somwhere if you just want pushbuttons.
maybe something like this?
http://cgi.ebay.co.uk/NLPBSSN-Enclosed-Sta...1QQcmdZViewItem
http://www.twin-turbo.co.uk
Ben,
I'm guessing (based on price) the later one is just two buttons and needs a separate contactor or however you spell it.
the latter one is just the front cover rob
Ben H
Member #: 184
Yep I guessed that too. I did mention it in the previous but, not very well though.
To be honest you can by a pedestel drill from Argos for £30 that has a start/stop controller. That seems the cheepest way to get one if you don't want to build it yourself. However 2 buttons and a relay in a box can't cost that much.
idealy you should include a reversing switch if possible, damn handy!
Ben H
Member #: 184
That is assuming that the motor will run in reverse.
Leonard
Member #: 806
Cirencester, Gloucestershire
isnt it called a no volt release switch? where if the power goes of and comes back on, the machine won't switch on again.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Certainly is. You REALLY need a NVRS or else you will, at some point, no matter how careful you are, have an accident. It might be horrible, you might get lucky but one thing is for certain ... it'll scare last nights dinner out of you!!!!
Something like RS stock number 398-5178 will be the easiest for you to impliment.
A question you need to ask yourself, as others have mentioned, is do you want to be able to reverse the motor? All simple AC motor instalations can be reversed. If you don't have reverse on the lathe's gearbox (as my machine doesn't) then it is VERY useful to have on the machine.
Leonard
Member #: 806
my grandpa had an old xl lathe that i used a few times. it was turned on by a light switch that was above the wall mounted motor, behind the flat belts it was driven by. that thing was f-ing scary to turn on!
