Home > Help Needed / General Tech Chat > t2 adapter plate
fordimus maximus
Member #: 1357
telford,shropshire
hey guys, ive recently had made an adapter plate using a drawing found on here, and also have done a search regarding fitting it.
however i came to fit it and buy searching other posts found that i need to mount it on a slight angle on the manifold?
when i offer it up to my manifold the only way that i am able to clear the old studs that i chopped off is to place it at a large angle, this will then throw the turbo out?
So is what im saying sound right?
if so would tilting the turbo cause any problems internally?
cheers
jamie
Dangerous
Member #: 417
Mines got the square hole in the plate cut at an angle so the plate goes on square
fordimus maximus
Member #: 1357
telford,shropshire
does your turbo sit at an angle tho?
My T2 sits at an angle. it's no problem with regards to running.
Nick
Member #: 154
Midlands
you can make out the position of the top 2 new manifold studs in this pic if it helps give you an idea.
and this one shows the angle my T2 sits on the metro manifold
fordimus maximus
Member #: 1357
telford,shropshire
thats brilliant thanks guys, ur pic has helped me with my other problem.
with the actuator what have you used to mount it, looks like a neat job?
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Fordimus ..... did you get any spares made up as I am still looking for one!!!!
Nick
Member #: 154
Midlands
no probs dude, the actuator mount is the std one that came with the turbo...if i'd made it there'd be more tape/cable ties *wink*
RogerM
Member #: 1217
It's a Nissan one Cherry / Bluebird I think.
Meastro / montyno-go diesel turbo one is easy enough to make fit too IIRC.
