Home > Wanted > Extra Long Clutch Push Rod
I'm after a clutch push rod that's about 1/8" of an inch longer than a standard vertro item, can any one help? Failing that I'll had to try and weld a bit on.
t3gav
Member #: 229
Gavin@minispares.com
kent
Ah this mod again, i'm sure you dont need to do this and is considered a bodge as apposed to fixing te problem..
Nick
Member #: 154
Midlands
i've got an old brass manifold nut wedged on the end of mine which has done the trick. i fitted a new arm/plunger/clevis pins etc and still couldn't get enough throw.
It's not a bodge at all. Sometimes crankshaft taper, flywheel taper and cranskaft endfloat will move all the stuff bacwards. I see this as a good solution to such problems.
Weld a 5/16 bolt on the rod. Job sorted!
miniminor63
Member #: 672
The oversills police
Oslo, Norway
backwards? Are you sure?*wink* Our cars are not like the Citroen DS with the box in front of the inline engine you know *tongue*
Sorry, forwards! :)
there is a nice adjustable one on that american site that sells nice mini stuff, cant remember for the life of me what its called though
http://www.sracer.com/
Damn, there's some good stuff on that page!
