Home > Wanted > V belt pulley to fit Nippon Denso alternator
As title, anyone?
Paul
what dimensions
Hold on Carl, Ill measure and show a photo of it too as it has an offset.
Paul
On 19th of Feb, 2007 at 06:38pm fastcarl said:
what dimensions
As you can see from the pics, it is offset so that the nut fits inside the pulley. Dimensions are;
62mm OD
38mm in V
15mm mounting hole
33mm nut recess OD
10mm offset
2.5mm wall thickness of mounting flange (between bearing face and nut face)
Are you thinking you can make me an alloy one Carl? How much?
Paul
Dangerous
Member #: 417
I turned down the boss of my n/d one and fitted a normal mini lucas pulley
ha ha , see you bust it getting it off too, so did i, lol.
so i made this
http://i24.photobucket.com/albums/c2/carl1...engineincar.jpg.
carl
Edited by fastcarl on 19th Feb, 2007.
i just used the one off the charade
why is everyone changing them? is it just because they broke when they were pulled off?
i made mine bigger to slow it dowm,
but it did bend getting it off, [stuck solid]
carl
antman
Member #: 358
Snetterton, Norfolk
Like the pulleys, not so sure on the red anodising though!
Jackman
Member #: 984
Westhoughton, Bolton
Yeah i like the pulleys too.
Manchester Minis
It was egg shaped when I got it, then I mangled it more getting it off to take the pictures.
Paul
I think your pulleys look ace carl
