Home > Show Us Yours! > dans new project car - morris 850
dan
Member #: 93
Okay those who probably saw my last car at the rolling day (orange 1380) probably were expecting something new seeing as the car basically need patching around the entire floor pan!
Well I have it now at last! I haven't had chance to sort out any proper pics yet but i've got one, doesn't really show the colour that well, its actually Suziki Green Yellow Colour.
There is a few bits and pieces to do like change the bonnet, get rid of the tinted glass etc. Probably a blow over at some point as it was painted 6 years ago!
Its got a 1275 A+ in at the minute thats only done 30k, but it will be making way for the 1380 so I can then get the turbo engine built up!!
http://www.turbominis.co.uk/pics/index.php...mg=LNA589P.jpeg
Its got a few good bits on it all ready, FIA Kevlar Corbeau's, minispares 4 pot calipers, should be a good basis hopefully!
Edited by dan on 14th May, 2004.
I can tell you that colours bright!!
Nice though and very very tidy!
Just needs a bit more poke under the bonnet!
1380Turboman
Member #: 221
Nice looking motor mate, good luck with the build.
PC
Looks really nice! but i liked the orange one, it had character *wink*
dan
Member #: 93
Yeah it sure did Alex, it was sorry to see it get towed away (some guy bought it just for the s brakes), it was even worse when he mailed me a photo of what happened on the way home, his old man had to do an emergency stop and the mini lept forward into the jockey wheel bar!! Put a good dent in the front panel!
This car is good base for working on, plus its actually on the road, needs some tweaks, and would be nice to have a colour change....
all in good time eh??
bad luck dan, mark knows what this is like too
dan
Member #: 93
i was just glad that it was no longer my car when it happened!!!
The guy that bought said his mate was going to use it for grasstracking so i guess it won't matter for them boys!!
dan
Member #: 93
Thanks for sticking the picture on iain
Just a quick update on the car, 1380 has now replaced the 1275, the head is currently with Mike Barrett for unleaded conversion, and sizing of chambers to give correct compression ratio for cam etc, also got some roller tips from Mike, and going to be using one of his custom air filters that he sells. The air filter was featured in minimag as part of a back to back test with Keith Calver at Mikes place, and it made 7bhp on a 1275 over anything else!!
The engine made 67bhp at the wheels at the rolling road in april so hopefully with the latest tweeks i might be getting near to 80bhp!
Still haven't forgot the turbo, but i'm not in a rush and i'm collected parts here and there
Got my vented discs machined down to 7.5" and the metro drive flanges on now, so the brakes should be more than enough
Edited by dan on 22nd Jun, 2004.
dan
Member #: 93
Just a quick update, had the car on the rollers that Mike Barrett uses last friday and it certainly feels alot different. For some reason the brand new carb i had fitted was a bit unusual in that the base of jet (bit where needle goes in) was quite low down, Mike said it was unusual but he managed to get round it. After which a bit of needle filing and bingo!
Unfortunately the rolling road calibration is out after having a new pot fitted (last one was fitted for 20 years!) so no real ideas on actual power.
Seems better than before when it made 67bhp at wheels so could be upto my 80bhp estimate.
Also found out my overheating problem wasn't real, Mike put a fully calibrated digi temp gauge on and turns out halfway between N and H was 74 deg C (thermostat temp) and H was 80 deg C. So i am fairly happy with that.
Looking at getting the car ready for the multipoint cage next, and getting the arches tubbed etc. Its going to be a slow project but going to try and keep it on the road over summer, and save the long dark nights for making progress!!
Where did you get that extra engine steady??
dan
Member #: 93
its an 'avonbar racing' item, got it off their website and it came through in a couple of days normal post.
Only thing I had to do was alter the metal bypass tube on the head as it prevented the head sitting onto the block properly. Fortunately I had the tube blocked with a brass plug, so i popped the plug out and ground the tube back till it would clear nicely.
I can vouch for these mounts, they seem to be very secure!
The offside one is the era turbo rover part available through minispares.
dan
Member #: 93
Finally got some pics sorted, cage is all in now, just needs some bits of tidying to do. Was going to go to town on the bodywork, but reckon i'll leave until all the running gear is sorted!
Carl
Member #: 95
liverpool-on-sea
well impressed with your welding mate did you do it yourself?
dan
Member #: 93
nah bottled it carl, with it being important i didn't want to make a mess!! the guy that did is good with the welder, he runs the minicentre in lincoln which is near where i work, and he has been playing with mini's for years, although normally all his 'tubbing' and stitching etc is on cars like autograss and rally cars where the end result doesn't need to look too pretty, so he had to take his time with mine!!
Edited by dan on 5th Jan, 2005.
dan
Member #: 93
managed to get a bit more work done over the new year break, still loads more todo mind, but thought i'd stick up some updated pics. I'm sure its been said before but can't believe the difference to access the removable front end is going to make!
clubman_dan
Member #: 142
Winchester
looking good
dan
Member #: 93
just got some more pics uploaded, loads more still to do!
Edited by dan on 12th Jan, 2005.
dan
Member #: 93
finallly got some wheel bolts for me old mamba's and got the old girl out the garage to sweep up some of the metal inards i've been chopping away, latest pic
plenty more to be getting on with, extra inspiration to be grabbed this weekend at avon i'm sure
Edited by dan on 14th Jul, 2005.
that looks great. Like something out of mad max!
dan
Member #: 93
cheers alex !!
i cant get my head aroound that picture-theres so much missing of the car
its looking good though
