Home > Technical Chat > standard actuator
mattyking
Member #: 873
Thatcham, berkshire
I no this has been asked lots but i searched and couldnt really find what i wanted.
basically i have a standard metro i beleive actuator. i want to run about 12 to 14 psi boost will it hold the boost. i ran 0.6 of bar on it before i needed rebuild the engine and it seemed ok at that. will it take the extra jip or not i dont want to find out to late when its at rolling road
Or a standard Cosworth one is good for 10psi.
Nope, physically it looks the same as a Metro one, it just has a stronger spring in it.
mattyking
Member #: 873
Thatcham, berkshire
so mine should be ok then. well i can try it. eventually ill change it as with many other bits i would imagine its difficult to do it all in one go i mean money wise and if it will last a while standard then thats good. cheers
